ADjusting headlights...
Old Sep 5, 2002
eXNBP's Avatar
eXNBP is an unknown quantity at this point
Anyone know how to adjust the height of the beam? One of the headlights points straight down while the others basically high beaming everyone[IMG]i/expressions/face-icon-small-sad.gif[/IMG] Anyone know how to adjust them[IMG]i/expressions/face-icon-small-blush.gif[/IMG] Thank you that is all [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 5, 2002
CivicManDan2's Avatar
CivicManDan2 is an unknown quantity at this point
i have this problem too. but mine are projectors.
Old Sep 5, 2002
platinumx310's Avatar
platinumx310 is an unknown quantity at this point
I THINK THE PROBLEM OCCURS WHEN U INSTALL NEW LIGHT BULBS FOR U CAR(SUCH AS HYPER WHITES). IF ONE SIDE IS LIL' HIGHER THAN THE OTHER
TRY TO FIT THE HIGHER SIDE CORRECTLY.
YEA...THOSE ARE HELLA ANNOYIN..ONE ALL NORMAL THE OTHER ALL HIGH BEAMY [IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Sep 5, 2002
Bartkat's Avatar
Open the hood and look at the braces that run across the tops of the headlights. These would be black painted steel. In each brace is an opening, or hole. Take a light and look down through that hole and you will see a white plastic disk with a hex socket in it. That is the adjuster. You can take the right allen wrench or a screwdriver and stick it through the opening and turn that white hex head. That will raise and lower your beams. I have had to do that every time I change bulbs because they all don't fit the same.
So just take a look with a good flashlight on top of the headlight housings and you should find that adjustment screw.
Old Sep 5, 2002
eXNBP's Avatar
Quote
[hr]Originally posted by: Bartkat
So just take a look with a good flashlight on top of the headlight housings and you should find that adjustment screw.[hr]
I know which screw your talking about but these aftermarket headlights dont have them[IMG]i/expressions/face-icon-small-mad.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Sep 5, 2002
eXNBP's Avatar
Aiight well just went out and took the headlights out, there seems to be 2 adjusters. Im presuming 1's for up and down and the other one is for left or right[IMG]i/expressions/face-icon-small-confused.gif[/IMG] Grrr looks like ill have to email Autodynmaics[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Feb 18, 2004
ramoMan's Avatar
ramoMan is an unknown quantity at this point
Hey barkat, is that for the Gen4 projector halo projectors? I hope so!
Old Feb 19, 2004
Bartkat's Avatar
No, what I posted is for the stock headlights.
Old Feb 19, 2004
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
u gotta take the bumper off then the lights off then adjust them while they are off the car then bolt em on....see where they are pointing make adjustments from there...thats how i adjusted my headlights
Old Feb 19, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
LOOK HERE ON HOW TO ADJUST!!!
-Locked-
Injen
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
TheRiddicles
Sep 21, 2015 01:28 AM
