fog/water vapor in -taillight-
after searching I know people have had problems with their headlights fogging up after clearing them, but I'm experiencing this problem with my right taillight.it fogs up in the brake light area and sidemarker area. I recently shaved off the EX emblem, do you think the heat could have damaged something? how would I go about taking the fixture apart and resealing it if I need to?
thanks in advance [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
well, after taking off the assembly, I notied about 25mL of water inside the lens. I dumped out most of it and am going to use a hairdryer to get the rest of the moisture out. but my main question is, how did it get there in the first place? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
simple question from both of u gentlemen.the moisture got inside from small crack or a seam.dry it out and let set under some sort of heat makin sure its dry.seal it usin automotive sealant (they r not cheap)
senicalj4579
Oct 2, 2015 10:03 AM
Spartanic
Jun 29, 2009 09:12 PM
sl33pyriceboi
Aug 4, 2007 05:48 AM
