Pls confirm usefulness of sway bar
Old Aug 31, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
Ok... Before anyone scream SEARCH at me please read the contents of what I have to say first.
I remember some discussion earlier (initiated by me) about "putting thicker sway bar on upgraded (shocks) suspension causes the suspension to lose stability that the stiffer shocks have accomplished due to over-rigidity". This was basically the nutshell conclusion from either the Hondastyle or the Honda Tuning articles.
I find it very reasonable looking at it from a Physic's point of view. My question now:
Who has sport springs + Koni's + RSX or thicker sway bar and can confirm the difference of the thicker sway bar? I'm under the impression that with a lowered and stiff suspension that a sway bar will make the tail too rigid to turn gracefully. I.e., I'd think it'd ride grate for smooth track on a slammed car, but would not be practical for normal driving conditions?
Old Sep 2, 2002
1955's Avatar
[IMG]i/expressions/beer_yum.gif[/IMG]very intuitive info regardin to a sway bar,in this case(yours),it will provide u with additional cornering power by lessen the rolling force from the chasis,bein rigid in a chasis is a plus to any car racer,u ever see the frame(roll bars) are welded together just for that reason?go for a thicker sway bar and stay outta trouble
Old Sep 3, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
I have koni shocks, eibach prokit springs, and the JDM RSX/Integra Type-R 22mm swaybar.
All I can say is, I don't know how I thought my car handled good before the swaybar.
Old Sep 3, 2002
MSoft's Avatar
Hmmm, ok. But did it affect your ride comfort? What stiffness level have you set for the Koni's?
Old Sep 3, 2002
Simkin's Avatar
Ride comfort stayed the same (if it had not gotten better), changing lanes became easier, a definate increase in lateral G's, and turning at all speeds became easier.
I usually keep my koni's set to 3/4 stiffness.
And during autocross events the car's push/understeer was dramatically reduced.
Old Sep 3, 2002
MSoft's Avatar
Hmmmmm... That's contrary to what I'd think would happen... Maybe I'll consider it. Next year's mod. Won't be able to pull much G's in Canadian winters anyway. Haha...
Old Sep 5, 2002
yittleblackcivic's Avatar
yittleblackcivic should not be trusted
so what do u guys recommend then.....sway or not?
Old Sep 5, 2002
Simkin's Avatar
I say its the cheapest fastest most satisfying suspension modification available. I would recommend it. And the 22m Type-R JDM anti-swaybar is actually cheaper than aftermarket ones, and just as effective.
Old Sep 5, 2002
Flash6009's Avatar
Flash6009 is an unknown quantity at this point
my question is it difficult to install on a civic that does not already have a sway bar...do you have to drill holes etc...
Old Sep 5, 2002
Flash6009's Avatar
i look in search and in the DIY and i found nothing
Old Sep 6, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I just ordered the progress rear anti-sway bar, it should be hear next week... I'll probably seel my stock bar if anyone wants to add it to their car witout one... Later
Old Sep 6, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
How do you get the JDM one?
Old Sep 8, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Quote
[hr]Originally posted by: Boilermaker1
How do you get the JDM one?[hr]
clubrsx.com.
EDIT: I think it runs for $150.
Old Sep 10, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
is the rear suspension in 7th gen Civic and RSX near identical?
Old Sep 11, 2002
Club2005's Avatar
Club2005 is an unknown quantity at this point
Well they use the same framing. now if they are exact, who knows as of yet. I just added the 19mm type S sway bar & a stripped bolt has it incomplete. Once on, I am sure it will make a difference. Wspecially after a lower tie rod, & the upper fron strut bars. I plan on picking up a front sway from a type S, to see if it fits and if I upgrade the back, I have to do the front somehow. :-)
Old Sep 13, 2002
orso's Avatar
orso is an unknown quantity at this point
it will make the car more neutral in the turns. prob be a little more stiff ride, but its all in what you want.
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Firefly
Nov 28, 2001 06:13 PM
jessepimpride
Nov 13, 2001 05:59 PM
