need help wiring my amp
Old Aug 30, 2002
Les's Avatar
Les
Les is an unknown quantity at this point
Ok I have a lanzar sl800d. It's a 1-channel mono d. I'll have 2 12" dvc at 4ohms subs coming in soon. I want a 1 ohm load. So from what I've been reading wire all the positives to the positive on the amp and all the negatives to the negative on the amp. My amp has 2 sets of speaker connections (+-,+-). It says this in the manual "Positive (+) and negative(-) speaker terminals are duplicated for ease in connecting multiple woofers." So does this mean I can run the negatives and postives of one sub to one of the +- on the amp and the same to the other? Will this still give me a 1 ohm load?
Old Aug 30, 2002
mohawkboom's Avatar
Here ya go!!!
Old Aug 30, 2002
LudlamTheory's Avatar
i boogie for the raindrops
i would just run out of one... thats an odd mono amp... you would have 2 2 ohm loads if you did that... unless the amp runs the 2 inputs parallel... then it woud be 1 ohm...
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
