New track times...
Old Aug 22, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
New track times...
God damn it, I need to fix my 3rd gear synchro... but anyway...
Headed out to the track with a few friends of mine. They were both running bikes (an R1 and an R6 respectivly) and had a great time squeezing off 12 second passes like nothing. I, other then when I found out i needed to break open the tranny, had a pretty good time my self. It was a beautiful day out. Warm and sunny, all adding up to = a high bottle pressure to start out with. It was actually warm to the touch when I checked it before staging (the zip loc bags filled with steaming hot water helped too). I wanted to get some baseline runs in first to compair later. First 2 runs were a disappointment. First run I bogged 1st and managed to net a 15.4@90 Mph. Both the 2nd and 3rd runs were 15.2 on the dot, with my best of being my 4th and final NA pass at 14.98@92 MPH.
With that out of the way, it was time to get some runs is on the juice. I staged shallow for my first run. Brought the revs up to 6K and slipped the clutch. Perfect launch. 2nd came allong and I activate the system., however going into 3rd, i jam the shifter between the gate and lose valuable time trying to get it into gear. I end up with a 14.4@98 MPH. The 2nd run, I didnt get the launch down quite as well, but the rest of the run went perfectly, netting me a 14.2@98.65. My 3rd and final run came later in the day, after the track had cooled off a bit. The outside air temp had to have droped near 10* F. This time I tried a different approach. I armed the system in 1st gear, and droped clutch @ 3500 RPM (my window switch doenst activate the N20 untill 4K RPM), the SLIGHTEST bog was felt, and i was off. I ground into 3rd because of my failing synchro, but it didnt slow me down really. The end of the pass came, and I had a good feeling. I really liked the way my car had launched off the line. I was supprised to find out, i got a best time for my self with a 14.07@99.2MPH, but with a bad *** 60' time of 2.1 seconds. (i usually get crappy 60' times, in the 2.3-2.4 second range.) Ill be posting pics of the goings on as soon as my brother returns my USB cable so i can upload the pics off my camera. I have some rather nice rice sighting pics as well that you may engoy.
-joe
Old Aug 22, 2002
wh3nw0rdsesc4pe's Avatar
wh3nw0rdsesc4pe is an unknown quantity at this point
Good job hoe. I mean joe.... oh crap those letters are so close.
nah I am kidding man, 14.07 is sweet. It should only get better from here. What shot are you running?
Old Aug 23, 2002
viciousvolpe's Avatar
viciousvolpe is an unknown quantity at this point
i can usually get good 60 ft...like 2.5 to 2.7 secs
but i got no power to hold it
maybe my pulleys wil help that when i get them on
Old Aug 23, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
Damn Joe...I just went though my slips and my best 60' time for me was a 2.485. Any tips you can give me next time I go to the track?
Old Aug 23, 2002
JoeB16's Avatar
Yes, for NA launches on low torque high RPM power engines (read: honda), you should slip the clutch at a high RPM (in my car, as i said, i do it @ ~ 6K RPM) this will allow you to stay in VTEC, while minimising wheel spin.
Old Aug 23, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Nice.
Old Aug 23, 2002
JoeB16's Avatar
Thx.
not to be rude, but i was able to "chirp 3rd gear" in a 95 Integra LS rental BTW.
Old Aug 23, 2002
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
Those are really good times
Old Aug 23, 2002
JKEEZO's Avatar
JKEEZO is an unknown quantity at this point
hey joe what track was this at???
Old Aug 23, 2002
JoeB16's Avatar
carlsbad
Bruce2
Sep 27, 2015 08:45 PM
