More S-AFC Settings help
Old Aug 19, 2002
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
OK. can someone let me know what are good settings to use for the High Throttle/Low Throttle settinigs and at what RPM.. Also the throttle point? the one by boosted is a little different so if anyone has an S-AFC.. let's here it..
Old Aug 19, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
Sorry, I cant help u out, but maybe u can help me.
Was it east to install? and is it confusing?
Thanks,
Lou-
Old Aug 19, 2002
wh3nw0rdsesc4pe's Avatar
wh3nw0rdsesc4pe is an unknown quantity at this point
If your not running nitrous or anything to make you run leaner do NOT go above 4%, you'll start to bog your engine and maybe even flood it.
My settings were gradually rising to 4% all the way across to 7000 RPM.
Low throttle start at -2%.
High THrottle start at 0%. ANd gradually go up between the two.
Old Aug 19, 2002
DogstyleEX's Avatar
yeah see..that's what i'm not understanding.. why would you even have a negative number? doesn't that defeat the whole purpose of the S-AFC?
Old Aug 19, 2002
u don't want the engine bogged down with fuel when you hit the gas at low throttle do you?? if you want leave it stock at 0. just trying to help man.
Old Aug 19, 2002
DogstyleEX's Avatar
thanks man.. i'm not doubting you.. i was just asking for my own clarification... anywho.. i was reading other posts about this and boosted posted something like it should be lik up to 20%??!?!? i'm not sure if this is right.. but i think 4-5% sounds more reasonable....
Old Aug 19, 2002
boosted is also running a 75 shot (i am pretty sure) of venom nitrous.
Old Aug 19, 2002
oh and my settings I told you were when I wasn't running my NX.
Old Aug 20, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
Do not set any negative numbers in the safc!
This will substract fuel.
0 is stock, do not go below stock.
Use negative numbers if you upgrade injectors or fuel system.
Do not set too much in low or narrow throttle, the engine will bog down.
Main increase are set in wide open throttle, and not too much if you are running stock, believe me.
Do not go over 12-15% the ecu will think you are running boost!
I recomend settings in wide throttle only (if stock), starting at 4000 or 4500 rpms and increasing to 7000 in a slope angle. Starting 4000/+2 and ending in 7000/+5 or +6.
This way my car felt the best!
Old Feb 19, 2003
PatrickB's Avatar
PatrickB is an unknown quantity at this point
Quote
[hr]Originally posted by: Jimmy24
This way my car felt the best![hr]
I was reading this thread and thinkin about what ppl where saying... after watch the a/f on a civic EX. the car from the factory runs rich. negative numbers are the only thing thats going to make power. so your sentence is kinda bad. Perfect a/f is where the most power is. Also you and another gentleman are adding fuel all the way to redline which is a no no. From what I am gathering you are adding increments through out the power band however thats not how engine works. The engine uses the most fuel where the torque and hp curve meet after that fuel starts to go down again. even though hp is going up. Hope this helps.
Old Feb 19, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
search on yahoo or something....i'm pretty sure theres some site with tweaks
GolNat
Nov 27, 2018 03:32 PM
JMKendrick
Sep 16, 2015 06:17 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
