Removing Paint on DIY trim pieces.....
Old Aug 14, 2002
pounds's Avatar
pounds is an unknown quantity at this point
alright...im kinda sick of the paint on my tirm pieces chiping and looking like S#!t...so im gonna take it off all the way and just get a metal trim kit!!!
Well...anyone know how to remove this? just ordinary paint remover or what? anything that will work good but not harm the trim plastic....
Old Aug 14, 2002
ricewashed's Avatar
ricewashed is an unknown quantity at this point
IF you did not use the surface prep( the one that "melts" your pieces so the paint sticks), you can use industrial masking tape to pull the paint off. I used it to remove paint off my door panels.
See the door panel? It had paint all over it. The speaker part is still black as you can see.
Old Aug 14, 2002
pounds's Avatar
thanks ricewashed,
that sounds like a good idea since i just sprayed on primer and paint.....but what bout all the little places that i cant fit tape into??
anyone know if paint remover will harm the trim piece itself?
Old Aug 14, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Using enamel remover (methyl alcohol) removes most paints, but also seems to melt the plastic a little, I used this to remove the paint I put on the HVAC controls.
Old Aug 14, 2002
ricewashed's Avatar
you can use a wire brush, not the one you use on a gas grill, but the one you use to clean aquarium pipes(tube cleaner) or a toothbrush. Once the paints starts to peel or chip, a little elbow grease can do wonders. Find something small enough to fit in there. A gentle scrubbing material would be desirable.
Old Aug 14, 2002
PlatnumBomb's Avatar
PlatnumBomb is an unknown quantity at this point
hmm...industrial tape u say???
Misfit2613
Jul 30, 2015 09:49 AM
Jul 12, 2015 11:54 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
BootyDo
Jul 7, 2015 06:06 AM
