Returnless fuel system? Huh?
Old Aug 12, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Ok, I keep hearing everyone saying this is the problem with our cars, and why there is no turbo yet. Can someone please explain to me what a returnless fuel system is, and how it differs from a normal one?
Old Aug 12, 2002
robbclark1's Avatar
Retired suspension supermod.
It is exactly what is says. The fuel lines in our cars don't sent the gas back to the tank but use it all up. The old civics used to send the gas back to the tank. The returnless system is supposed to help with MPG.
Old Aug 12, 2002
APS's Avatar
APS
Oh, as simple as that huh. Exscuse me for being ingnorant, but why does that makes such a difference in a turbo application?
Old Aug 12, 2002
robbclark1's Avatar
That i don't know. I am new to the scene. Grey would be the man to ask since he has been researching turbos. I think it has something to do with not getting enough fuel to the car to handle the excess air that the turbo is putting in.
Old Aug 12, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
Robb you are correct sir. With a returnless fuel system you need to tell the ECU that you are getting larger amounts of air into the engine, so it can send the needed fuel.
Old Aug 12, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
if it cant return excess fuel it has to pump it at a lower pressure in order for it to work right...turbos need higher pressure than our system can provide. so if we GIY a return line for the fuel system, and add a higher flow fuel pump, it will work. (except in the state of california)...and HKS USA is based in cali so all their kits have to be legal there first.
Old Aug 12, 2002
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Quote
[hr]Originally posted by: 4drcivic2k1
if it cant return excess fuel it has to pump it at a lower pressure in order for it to work right...turbos need higher pressure than our system can provide. so if we GIY a return line for the fuel system, and add a higher flow fuel pump, it will work. (except in the state of california)...and HKS USA is based in cali so all their kits have to be legal there first.[hr]
good call man. i dont think it would be too hard to do a DIY.
Old Aug 12, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
I take it it's the same for Superchargers as well. Both used forced induction so they need higher quantities of fuel, right?
Old Aug 12, 2002
dragoon's Avatar
but if there was a turbo, wouldn't we just have to reset the ECM and let it "learn" how much air it's getting?
Old Aug 12, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
and if you had longer legs you might be able to run 50mph, not sure if the ECU can make the fuel pump, pump as fast as needed.
Old Aug 12, 2002
nbpEMCivic's Avatar
Poop is also correct, the stock fuel system could not handle the fuel needed for forced induction.
Old Aug 12, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
In a nutshell, you need a properly engineered fuel rail with a return fuel line to the tank, a higher-pressure pump, a rising-rate fuel pressure regulator, and bigger capacity injectors with a modified duty-cycle to work with the turbo. Add to this either a piggy-back fuel computer or a stand-alone programmable ECM. Not quite sure if all this is worth the trouble in a Civic but I AM sure someone will do it.
Old Aug 12, 2002
trevor's Avatar
trevor is an unknown quantity at this point
Quote
[hr]Poop is also correct, the stock fuel system could not handle the fuel needed for forced induction. [hr]
we could upgrade to the RSX fuel pump....
but it's in the gas tank........how the hell do we get it out.........
and if we did upgrade to the RSX......how would the ECU react???.........
Greddy has allready turbo'd the RSX and the Celica has been turbo'd too.
They are both returnless system's....
so how the hell did they do it???........
[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Aug 12, 2002
Quote
[hr]Originally posted by: trevor
Quote
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
They may have been able to come up with some sort of fuel map that presicely meters fuel flow/pressure as the engine needs it...theoretically, this is not too difficult since all needed sensors are in place (MAF, TPS, manifold vaccuum) all that would need to be added is a fuel pressure regulator and bigger injectors. A knock sensor wouldn't hurt either...
Edit: This would require precise ECM tuning to tie all sensors into the system and precisely control the fuel mixture...this would leave very little room for error!
Old Aug 12, 2002
nbpEMCivic's Avatar
The Sport Comapct Car magazine's project Matrix is something we could learn from. Very high comperssion ratio, returnless fuel system, yet they turbo'd it and did it damn well (it survived the trip from Cali to Houston). It's in the May of June issue I belive, or search thier web site here.
vtecbrah
May 31, 2015 01:24 PM
PJ
Sep 5, 2003 01:00 PM
2k2civic
Jan 22, 2002 10:13 AM
htowncivicEX
Jan 21, 2002 11:48 AM
TaiChi
Dec 17, 2001 09:09 PM
