HEEEELLLLPPP!!!!!!!!!!! ATTN: People with Ground Control Coilovers...HELP! I have Noises in the fron
Old Aug 10, 2002
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
ATTN: People with Ground Control Coilovers...HELP! I have Noises in the front
I just got my ground control coil overs installed today, and the drop looks great but i have a weird noise when i turn the wheel in the front left spring...is it normal? or should i be worried? I heard some one once saying it will go away, but it soundsl ike the spring is getting twisted or like squashed or something...i dont know? is it normal or not?
Any help pleassseee?
Old Aug 10, 2002
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
i had that noise in the right rear for about 3 days then it went away, im pretty sure its normal and itll go away
Old Aug 11, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Tell me this, have you taken off your tire and inspected your gcs? Are you sure it has to do with the spring. The strut is not the only part to move when you turn the wheel.
Old Aug 11, 2002
alltech01civic's Avatar
White Pony
alltech01civic is an unknown quantity at this point
almost everyone has had this problem with ground controls or skunk2 coilovers.....if you go to "suspension performance" in the upper toolbar, im pretty sure there will be a thread on this subject, if not search for it!....a couple ways to fix it is either buy another rubber piece from honda that goes between the top hat and the top of the spring, or you could get some oil and rub it all over the two.....i have this problem also, just havent had time to fix......oh yeah and dont worry about it, nothing is gonna break....it's just metal hitting metal !!!
Old Aug 13, 2002
TOOLOWCIVIC's Avatar
I had the same problem it went away.
Old Aug 13, 2002
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
New springs will do that - they need to be broken in also.
Old Aug 13, 2002
sweetness's Avatar
sweetness is an unknown quantity at this point
I had that problem too. Don't worry about it. Seems pretty normal.
Old Sep 27, 2002
I was driving today and I heard that noise again. I've had my coilovers for about 8 months now. Every time I hit a bump it makes a popping clicking noise in the front left. This is normal right[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 27, 2002
VNlilMAN's Avatar
The Standard One
like alltech01civic has said it probably isnt doing any harm, just metal hitting metal... i know with springs most of the noise is caused by the spring touch on the bottom perch... your supposed to put a rubber tubing between it and also, the top perch has to be aligned right. not sure what the exact problems with coilovers are tho.
Old Sep 28, 2002
TuffVietta's Avatar
TuffVietta should not be trusted
http://www.energysuspension.com/sboots.html
i think that link helps. just purchase the coil isolators then stick it above the spring. anyone know which size would fit skunk2 coilovers?
i'm really getting tired of the clicking noise whenever i turn.
Old Sep 28, 2002
What are those for?
Old Sep 28, 2002
VNlilMAN's Avatar
The Standard One
they basically prevent the springs from rubbing against the top/bottom perch. the tube is like the stock ones that go on the bottom of the spring(where it sits on the bottom perch). my car didn't come with it... only if i knew of that earlier...
Old Nov 11, 2002
ASWZero's Avatar
Vibrations are the roots of the noises. I heard GC have a poly-urethane upper perch. That could be the cuplrit(one of them) and the other is the spring. The bearing on the strut(how our car turns) could also be making some noise.
1028CiViC
Nov 24, 2001 02:14 PM
duyaknow
Nov 23, 2001 07:28 PM
TOOLOWCIVIC
Nov 18, 2001 10:17 AM
JumpingBean
Nov 17, 2001 04:53 PM
ImmortalEX
Oct 20, 2001 09:08 PM
