QUESTIONS ABOUT SWITCHING TO SYNTHETIC.
Old Jul 29, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
gefore you all flame me, i searched, and was unable to find the answer to my question. ok, i have been told by some sources that if i switch to synthetic oil from regular oil, that it would be necessary to replace all of the gaskets because of the diffrent effects of the two types of oil. they said that the synthetic tends to shrink the gaskets, and the regular oil makes them swell. meaning that the gaskets will get smaller and result in an oil leak if i do not replace them. is this true? also, which synthetic do you reccommend? i was wanting to go with Royal Purple.
Old Jul 29, 2002
klam's Avatar
klam is an unknown quantity at this point
I am not aware of any problems using major brands of synthetic, from reading other's posts and my own experience. This may become more of an issue when your car reaches higher mileage.
I use Mobil-1 5W30 with success. Others swear by Amsoil or other brands.
Old Jul 29, 2002
Kung's Avatar
Kung is an unknown quantity at this point
That getting new gaskets thing is a full load of BS. They're trying to take your money. The only suggestion I would have if you switch to synthetic is not to switch back to regular.
Old Jul 29, 2002
Collective's Avatar
Collective is an unknown quantity at this point
Check out mobil 1 They will answer alot of questions...
Old Jul 29, 2002
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
Quote
[hr]Originally posted by: ce01cvcex
gefore you all flame me, i searched, and was unable to find the answer to my question. ok, i have been told by some sources that if i switch to synthetic oil from regular oil, that it would be necessary to replace all of the gaskets because of the diffrent effects of the two types of oil. they said that the synthetic tends to shrink the gaskets, and the regular oil makes them swell. meaning that the gaskets will get smaller and result in an oil leak if i do not replace them. is this true? also, which synthetic do you reccommend? i was wanting to go with Royal Purple.[hr]
Any of the good syths will be fine, mobil1, amsoil or royal purple. i went amsoil in mine.
synth oil info
Old Jul 29, 2002
solar's Avatar
solar is an unknown quantity at this point
In your owners manual they go into some detail about Syntheic oil, Honda says its fine to use, but to use 5w-20. Mobil 1 e-mailed me a few weeks ago saying that 5w-20 should be avaliable by the end of this year.
Old Jul 29, 2002
Grey's Avatar
DIY King
That's great news. Even though people run 0w-30, I just don't know that much about oil to run anything else than what is reccomended in the manual. When Mobil releases the 5w-20 I'll try it out. That is if it's full synthetic?
Old Jul 29, 2002
Numinous001's Avatar
Numinous001 is an unknown quantity at this point
Quote
[hr]synth oil info[hr]
Excellent Article!
-Numinous
Old Jul 29, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Quote
[hr]Originally posted by: Grey
That's great news. Even though people run 0w-30, I just don't know that much about oil to run anything else than what is reccomended in the manual. When Mobil releases the 5w-20 I'll try it out. That is if it's full synthetic?[hr]
I've explained this millions of times on this forum but here we go again. I will never, ever use 5w20. 5w30 is perfect. F#ck the manual. The only reason they suggest it is because it's what they used in their gas mileage tests and emissions. But, used over a long period of time when you rev your car over 3k RPMs that oil doesn't provide nearly enough protection against thermal wear because it is too thin. It hurts your engine to use such a thin oil over a long period of time.
Old Jul 30, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
i use 5w-30 and i love it, and oil change done by myself cost me 31 bucks, full synthetic and a mobil1 syntehtic fitler.
Old Jul 31, 2002
SpitakHye's Avatar
SpitakHye is an unknown quantity at this point
UMM, i used CASTROL SYNTEC, and the bottle said that it was fully compatible with regular oils. and besides, its like olive oil and vegetable oil, they are both oils, but one is just better
Old Jul 31, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
that information is false. The only time you have to worry about gaskits are if you have 100,000+ miles on the car and then you switch to synthetic. Just cause it is thinner and you seals may be worn. If you do it now, you wont have any issue's down the road. It is actually better for the car. As for oil, I run mobile 1, 10w30 all year round. Done it with all my cars, and it works the best.
Old Jul 31, 2002
bhaz413's Avatar
Quote
[hr]Originally posted by: solar
In your owners manual they go into some detail about Syntheic oil, Honda says its fine to use, but to use 5w-20. Mobil 1 e-mailed me a few weeks ago saying that 5w-20 should be avaliable by the end of this year.[hr]
the only reason they say use 5w-20 is because it is really thin, and if something breaks on your car, they will repair it and not being udner warrenty. Its only so they can get more buisness. Ford is doing thesame thing now. I heard this straight from my tech guy at honda.
h4ldol
Jun 3, 2015 03:26 PM
werdnahall
May 17, 2015 11:37 AM
BootyDo
May 7, 2015 04:46 PM
viper775
Dec 9, 2001 10:52 PM
klam
Nov 16, 2001 03:36 PM
