Difference between 2dr/4dr sportlines?
Will they phyically fit on the 2dr model if they are from a 4dr model? Are the rates different. Need info planning on buying from a friend soon.
The Standard One
ya eibach only has one version... its made for both 2 door and 4 door but on the 4 door it doesnt look right cause the back is lower then the front. it should be fine on the 2 door tho. if they did make 2 different ones however, chances are the spring rate and everything would be the same.. only difference would be the height of the rear. this is what the difference between neuspeed and goldlines 4 door and 2 door is. just the rear height.
JetsterDajet
52
May 8, 2016 12:11 AM
TheRiddicles
Sep 21, 2015 01:28 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
