Front speaker install
Old Jul 23, 2002
Yuendawg's Avatar
Yuendawg is an unknown quantity at this point
I have a pair of Polk 602a speakers. I know you have to use a spacer to install these speaker. Will a 1 inch spacer work here?? Or do I have to use a 1/2 in???? How hard are these to install??? I also have the universal brackets from Crutchfield to use as well. any help would be appreciated.
Old Jul 23, 2002
mohawkboom's Avatar
a 3/4" Spacer will do..if you use a 1" Spacer you'll have to cut the rings off the door panels..
Old Jul 23, 2002
Ed's Avatar
Ed
i was goign to get those speakers fo ra while, if i can remember right, according to crutchfield, those could fit without any spacers, what's what made me want them initially.
-Ed
Old Jul 23, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: Ed
-Ed[hr]
Withotu spacers if you don't want to rll down your window.. for most shallow mount speakers.. reversing the supplied speaker ring makes an adequate 1/4" Spacer [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 23, 2002
klam's Avatar
klam is an unknown quantity at this point
Quote
[hr]Originally posted by: Yuendawg
I have a pair of Polk 602a speakers. I know you have to use a spacer to install these speaker. Will a 1 inch spacer work here?? Or do I have to use a 1/2 in???? How hard are these to install??? I also have the universal brackets from Crutchfield to use as well. any help would be appreciated.[hr]
I have those exact speakers, I used approximately a 1/2" spacer (I didn't measure). I just used a Scosche universal mounting bracket, and modified it a bit to get it to fit.
The speakers are great, you'll enjoy them!
Old Jul 23, 2002
dnutz's Avatar
dnutz is an unknown quantity at this point
I did a DIY on a spacer using the stock speakers. I used a Dremel tool and cut out the old speaker and frame leaving a small ring of plastic to mount to. It was kind of trickey to mount the speaker to since all of the holes didn't line up with the spacer so what I did was use a longer metal screw and screw directly into the door.. holds GREAT and doesn't rattle..
Old Jul 23, 2002
Yuendawg's Avatar
Klam,
I have the same exact stuff. How did you modify the Scosche universal mounting bracket??? The damn thing doesn't mount flush with the Bracket. Could you explain in more detail since I am planning on doing the same thing as you. Thanks
Old Jul 24, 2002
fonto's Avatar
The LA Clipper
I recently installed the Polk EX3 6 1/2s. I just used the ring that held the grill as a spacer and it worked perfectly. I tried to put the speakers in as low as I could in the weird shaped speaker hole, and I drilled holes with a 1/8th drill bit. Everything turned out cool...it was alot easier then doing the back speakers!
Old Jul 24, 2002
klam's Avatar
With the Scosche bracket, first I sawed off some of the protruding arms so that the bracket would sit flush on the door. Otherwise, those little arms will get in the way. I then used a template to mark off three holes to drill, marked spots on the bracket and the door. The three holes should correspond to holes on the speaker basket. Then I drilled the bracket. You will also need to drill the sheet metal surrounding the speaker. Make sure these are as accurate as possible. One way is to use a very small pilot drill and then go in again with the proper size drill. I used 1/8".
Then you mount speaker + foam ring + bracket to the door and secure with screws. Also, before you secure the speaker, connect the wires. It may also be a good idea to put a little grease in and around the holes to make it thread better and to prevent any rust from forming.
I've attached some pictures.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] BrownBread 3.jpg (93 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Polk EX602A.jpg (63 Kb)
Old Jul 24, 2002
klam's Avatar
In my first message, I said a 1/2" thick spacer. I forgot to mention that there is a foam ring too. The combo of foam ring and Scosche bracket does the trick. Before you put everything together, try rolling down the windows to see if the back of the speaker clears.
Old Jul 24, 2002
Yuendawg's Avatar
Thanks, those pics are great, helps me out a lot. I don't have the foam spacers though?? What else can I use?? Did you use the screws that came with the bracket??
Old Jul 24, 2002
klam's Avatar
Yeah, foam rings came with the speakers?
I used the screws that came with the package too.
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
ademarco6
Nov 16, 2001 10:19 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
