Im Bored i thought i would ask a question
Old Jul 22, 2002
Crash2002's Avatar
Crash2002 is an unknown quantity at this point
lets say a subwoofer has 1000Watts RMS and u have 2 500 watt amps do u just hook up the 2 amps to the sub? or what? its a question i have been wondering for a while? Mohawk or Whiterabbit? im sure you 2 know
Old Jul 22, 2002
mohawkboom's Avatar
It depends on the ompedance of the voice coils..and the amps you have.
Say it's a Dual 2ohm sub. And you have 2 amps that put out 500Wrms into a 2ohm mono load. Wire one amp to each voice coil and there you go..
Cheers
Mohawk
Both amps have to be identical though.. there are also some amps that can be strapped..making one put out only a + signal..the other a- .
Old Jul 22, 2002
02CivicEX's Avatar
02CivicEX is an unknown quantity at this point
if the amps are 500 watts than they are close around 250 rms depending what ohm they are wired to ..each amp. if your sub is 1000 watts rms then each coil is 500 watts rms. 250 watts rms to each 500 watt rms coil would be fine but if u want to get the best out of that sub i would sell both amps and buy a mono amp that will supply at least 900 wattts rms.
sorry that was a little off of the main Q
It mostly depends if the subs are dual voice coil or not
Old Jul 22, 2002
mohawkboom's Avatar
who rates amps in peak wattage? [IMG]i/expressions/face-icon-small-smile.gif[/IMG]..I always talk in RMS..[IMG]i/expressions/face-icon-small-smile.gif[/IMG]. but the amps would have to be the same make/model and gains set the same..
Old Jul 22, 2002
02CivicEX's Avatar
[QUOTE]Quote
[hr]Originally posted by: mohawkboom
I know u know what u r talking about, but in his Question he said 1000watts rms for the sub and did not state that the 500 watt amp wass rms or peak.
i allways talk in rms also. but most company's dont! and alot of kids that dont know much about car audio use peak wattage also
It sounded like he didnt know much, so i added my 2 cents, kinda seamed like you were offended I know u put a smile face in there but if it offended you in anyway i apologize
honda200192
Suspension
Oct 27, 2019 12:23 PM
juror
May 26, 2015 06:35 PM
eorlando1
May 17, 2015 11:16 AM
trevor
Dec 4, 2001 04:12 PM
