Attaching AMP's to backs of rear seats
Old Jul 20, 2002
Vinz's Avatar
Vinz is an unknown quantity at this point
How do you guys mount your AMP's to the backs of the seats of the sedan? It doesn't feel like there is anything to screw into (Maybe I am wrong). Anyway, I have seen quite a few people do this and I need to clean up my install.
Old Jul 20, 2002
mohawkboom's Avatar
there isn't anything there but some bars.. Remove the carpetting from the back of the seat. use some 1/2" MDF or plywood.. place it behind the bars. Use some small U-bolts to hold it in.. then put the carpetting back on..and screw the top board into the board in the back..
Old Jul 20, 2002
mohawkboom's Avatar
If the amps are small enough you can still put both seats down seperately..if one amps too big..you have attach both seats together with the board..
Old Jul 21, 2002
form3hide's Avatar
form3hide is an unknown quantity at this point
I attached mine to the metal polls in the seats with some off those white zip-lock pulley things
Old Aug 9, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Quote
[hr]Originally posted by: form3hide
I attached mine to the metal polls in the seats with some off those white zip-lock pulley things[hr]
Man, that's some ghetto a$$ shiit! (I'd do the same thing)
Old Aug 10, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
Here is what I did in my car:
My Rear Seat Install
Old Aug 11, 2002
01civic911's Avatar
01civic911 is an unknown quantity at this point
you can line it up to be able to screw either the top or the bottom to one of the bars, and then for the other side, use a set of black zip ties and just tighten them really tight and it will not go anywhere, i did this a year and a half ago, and it has yet to move off the seat.
mistermenphis22
Apr 3, 2016 08:06 AM
Micks2K1
Nov 14, 2001 09:33 PM
Bjmayo523
Nov 9, 2001 07:39 PM
CosmicPulse
Nov 9, 2001 05:06 AM
