installation w/ 2 amps
Old Jul 7, 2002
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
2 10" subs running off of a 1000 w 2 ch amp.... i have installed component speakers in my front doors and i would like to power them from another amp identical to the first one... i have already pulled all the speaker wires, i'm wondering what i need to do to get power, remote switch, and inputs into the 2nd amp -- can i do this w/o going back to the deck? can i use the original power wire or do i need 2? (another 1 to the battery)... fuse distributer? etc etc.
also i wired my 2 10's so that i have a total impedence of 4 ohms.. on one channel. my amp has a switch on it for stereo and mono. in the manual it says that when mono is activated only the left input is used. does this switch make any difference in the amount of output power by the amp? i would like to get both left and right. should i hook up these subs to 1 channel or do the bridged connection? and which switch position should i use? mono or stereo? thanks for reading this novel.
Old Jul 7, 2002
white97ex's Avatar
white97ex is an unknown quantity at this point
run your power and ground wire into a capicitor...running 2 amps and one of them being 1000w your going to need at least a 1/2 faret.
Off of your capacitor then run 2 power wires to each amp and 2 ground wires to each amp. You can split the remote wire or even run a little link inbetween the 2 amps for that.
Old Jul 8, 2002
PK2K1's Avatar
thanx... actually both amps are 1000w. does that change anything?
Old Jul 8, 2002
white97ex's Avatar
nope.
1 power wire from battery to cap, then 2 power off cap to each amp. then 1 grounded wire to cap, 2 grounds to each amp.
id run a full faret cap if i were you...and make sure to use good size gauge wire, dont wanna mess around when your runnin that kinda power.
Old Jul 10, 2002
pinoyVTi's Avatar
pinoyVTi is an unknown quantity at this point
Quote
[hr]Originally posted by: PK2K1
also i wired my 2 10's so that i have a total impedence of 4 ohms.. on one channel. my amp has a switch on it for stereo and mono. in the manual it says that when mono is activated only the left input is used. does this switch make any difference in the amount of output power by the amp? i would like to get both left and right. should i hook up these subs to 1 channel or do the bridged connection? and which switch position should i use? mono or stereo? thanks for reading this novel.[hr]
powering speakers in your front doors with a 1000w amp? What speakers do you have in your doors?
Hey mohawk..can ou alternators keep up with 2 1000W amps?
You can just get distribution blocks to add another amp. No need to go back to the HU to get the remote wires...
Old Jul 10, 2002
mohawkboom's Avatar
2 1000W peak output amps yeah.. 2 all out 1000W Amps.. No..but then again neither can yuor ears... Which amps specifically are we talking here?.. the only 1000W Amps than I can see fitting your intention are Arc Audio 2500CXLs .. are these the puppies?
Old Jul 10, 2002
PK2K1's Avatar
kenwood kac-929 (but the 1 on the components is at 8 ohms i believe)
Old Jul 10, 2002
PK2K1's Avatar
plz check the thread entitled "BIG ODD PROBLEM"
GolNat
Nov 27, 2018 03:32 PM
metalpres
Sep 23, 2015 05:22 AM
Mc7602
Sep 17, 2015 02:01 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
