strobes and lava tubes
Old Jul 6, 2002
vtecbabe01's Avatar
vtecbabe01 is an unknown quantity at this point
Has anyone installed strobes lights in their headlights or front grill and a neon lava tube? I have a switch for the strobes, but need one for the tube. can anyone help me out with DIYs or something. Thanx
Old Jul 6, 2002
Bigdaddyd59's Avatar
Bigdaddyd59 is an unknown quantity at this point
I put strobes in my headlights and i just put a seperate switch on mine next to the 12volt dc plug in real simple i picked them up at pep boys and all you had to do is drill a 1/2" hole in the headlight. Just drill slowly and take your time. I would suggest putting them on constant power so that you can show your friends when you want to. What do you mean by lava tubes, just put them in a seperate switch also.
Old Jul 7, 2002
QCKSILVR's Avatar
QCKSILVR is an unknown quantity at this point
I have strobes in the headlights, back turn signals and back reverse lights but they're the Whelen ones that are used on police cars. They required a 1'' hole to be drilled in each fixture and the strobe tube then pops in. They run to a power supply mounted in the vehicle which runs to the battery and then a toggle switch mounted in the console.
It's illegal to use these in most states unless you are authorized to use them.
jdh022764
18
Nov 3, 2015 06:44 AM
Bruce2
Sep 27, 2015 08:45 PM
General DIY
Sep 25, 2015 08:02 PM
MichaelLW
Sep 14, 2015 07:15 AM
Bricoleur
Sep 9, 2015 06:48 PM
