upper strut bar
em2
upper strut bar
i did a search and didnt find what i was looking 4. let me make that clear so b4 so one starts flaming. im new to all this honda stuff and i wanna no is can anyone post a DIY on the upper strut bar because i thought you jsut take the bolts off of the tower bars and put the strut bar on, put the bolts back on and ur done. i been reading you gotta jack up the car and if u dont ur suspension can fall out. im so confused [IMG]i/expressions/face-icon-small-confused.gif[/IMG] so can anyone put a DIY. thanks 4 ur time.
installing the upper strut bar should be as easy, if not easier than "installing" a shift ****. all it requires you to do (for either case) is:
1) remove existing fastening members, aka bolts on the strut tower, or the shift **** itself if you're doing a shift **** replacement excercise.
2) install new toys, eg. upper strut bar or shift ****
3) turn the OTHER way. yes, i bet you figured it allll out by yourself.
the bit about raising the car? dont worry about it. ignore it unless you have your suspension heavily modified. but if you do, and you're asking about installing a strut tower bar, i should have you btchslapped in about 1/2 second flat.
