upper strut bar
Old Jul 3, 2002
sspem2's Avatar
em2
upper strut bar
i did a search and didnt find what i was looking 4. let me make that clear so b4 so one starts flaming. im new to all this honda stuff and i wanna no is can anyone post a DIY on the upper strut bar because i thought you jsut take the bolts off of the tower bars and put the strut bar on, put the bolts back on and ur done. i been reading you gotta jack up the car and if u dont ur suspension can fall out. im so confused [IMG]i/expressions/face-icon-small-confused.gif[/IMG] so can anyone put a DIY. thanks 4 ur time.
Old Jul 3, 2002
woohooh00's Avatar
woohooh00 is an unknown quantity at this point
installing the upper strut bar should be as easy, if not easier than "installing" a shift ****. all it requires you to do (for either case) is:
1) remove existing fastening members, aka bolts on the strut tower, or the shift **** itself if you're doing a shift **** replacement excercise.
2) install new toys, eg. upper strut bar or shift ****
3) turn the OTHER way. yes, i bet you figured it allll out by yourself.
the bit about raising the car? dont worry about it. ignore it unless you have your suspension heavily modified. but if you do, and you're asking about installing a strut tower bar, i should have you btchslapped in about 1/2 second flat.
Old Jul 3, 2002
sspem2's Avatar
em2
fu** u man i asked a dam question that i was confused on u bit**
Old Jul 3, 2002
VNlilMAN's Avatar
The Standard One
-locked- this was/is being discussed in the other thread
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
speedlever
Sep 24, 2015 07:18 PM
