UPDATED PICS!!!!!!
Old Jul 1, 2002
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
UPDATED PICS!!!!!!
check it out fellas[IMG]i/expressions/face-icon-small-smile.gif[/IMG] what do yall think? i havent updated pics in like 3 montsh so here they are
James
Old Jul 1, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
looks good try to clean the look up thou and it would be hella tight your custom trunk was a good idea but it does not have that clean look im not dissin your ride its tight just giving my opinion
Old Jul 1, 2002
woohooh00's Avatar
woohooh00 is an unknown quantity at this point
you're tryin reeeeeeally hard arent you? [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
just curious, what is the intake wrapped in?
Old Jul 1, 2002
jamesbbh's Avatar
thermo-tec heat shield tape type stuff o and the trunk i sso tall b/c i needed all that room for the eclipse sub
Old Jul 1, 2002
skitzo's Avatar
skitzo is an unknown quantity at this point
That thermo tape makes the intake look like a homemade ghetto rig job.
Old Jul 1, 2002
sadboy916's Avatar
how much more did you pay for the wrap seems like a waste
Old Jul 1, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Very sweet ride I like it, good work
Nick
Old Jul 1, 2002
jamesbbh's Avatar
i'm not worried about it, the tape keeps the air cold so im leaving it on there
Old Jul 1, 2002
jamesbbh's Avatar
i didnt pay anything for any of the wrap, my friend had it all left over b/c he bought too much and i just wrapped everything up. it really does keep everything cool
Old Jul 1, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
Actually the wrap is a great idea! It is usually is used on the intakes of a turbo and the exhaust manifold! It is good for keeping things cool as well as keeping the heat in! I would have done the same thing wrap the header to keep heat in and wrap intake to keep the cold air truely cold! Dakota
Old Jul 1, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
Nice toys.....
Old Jul 1, 2002
jamesbbh's Avatar
THANK YOU dakota, finally someone sees it from my point of view
James
Old Jul 1, 2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
nice ride[IMG]i/expressions/beer_yum.gif[/IMG]
Old Jul 1, 2002
B390LU's Avatar
B390LU is an unknown quantity at this point
Nice Car!!The combination of your wheels,the drop and the bodykit looks good.Your wheels look bigger considering they're 17" which is good [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Make sure u keep us updated on your progress with the car and good luck with the trunk work.Btw,with your 17" and neuspeed race,how many finger gap at the front and back if u don't mind me asking.
Old Jul 1, 2002
aznboy808's Avatar
aznboy808 is an unknown quantity at this point
hey how does that eclipse titanium sub sound? i never heard them before
Old Jul 1, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
Looks great. Yes, the wrap kicks it. VERY useful stuff, good job wrapping the header too. Do you have it wrapped back to the cat? If not, you should. You can wrap your fuel lines with that same reflective you have on the intake too. Every little bit helps. I predict that eventually you (and I) will crack that DC header with it wrapped like that. But, so what, by then someone will have made one that really gives us some results. Or maybe a turbo?
Old Jul 1, 2002
jamesbbh's Avatar
haha excellent call family man, o and yes the eclipse sounds better than 2 of my old mtx 6000's. and the finger gap in the front is like 1 i cant fit a finger in the back
thanks a lot guys
James
Old Jul 1, 2002
jamesbbh's Avatar
o and familyman i just had enough to wrap it til the flexpipe(which is under the car) so i guess its ok
Old Jul 1, 2002
civicvtec1ps's Avatar
Search and Learn
just quick question since you have same intake as mine. what is the size of aem bypass 2 1/2 ?
AIM NAME - PEACEMAKER1PS
Old Jul 1, 2002
SLiCKGreeK's Avatar
SLiCKGreeK is an unknown quantity at this point
the car is G'eed up fron the seat up..lol
Old Jul 1, 2002
SQCivic's Avatar
SQCivic is an unknown quantity at this point
There are both pros & cons to wrapping a header. I would suggest anyone considering it to do some research first.
Car looks good!
Old Jul 1, 2002
FamilyMan's Avatar
SQCivic: help us out. What are the cons? Save us the time and trouble of research. Thanks.
Old Jul 1, 2002
SQCivic's Avatar
I'm no expert on this, just relaying some stuff that I have read about wrapping a header. Here are a few things I found just by doing a Google search...
We get lots of questions about the thermal wrap products that are seen on various classes of competition cars. it's natural to assume that because racers use a product, it must have some performance benefit. The theory behind thermal wrap is that maintaining the combustion heat in the exhaust system improves scavenging. But on street driven cars any small advantage you might gain is offset by ugly side effects.
Racers don't mind replacing exhaust system components frequently -- you will. On street driven cars, you want to get rid of the heat. The higher the exhaust system temperature, the faster you'll burn out gaskets and destroy the headers, converters and mufflers. Unless you've got money to burn, our advice about using thermal wrap is DON'T!
Thermal wrap does a better job at insulating heat and reducing under hood temperatures, but they also tend to hold in moisture and cause rust. If you use wrap on a street car, you should use a coated header to help it last. Headers will not last as long if they are run hotter, and wraps make the header run much hotter. The metal will fatigue much quicker. Gaskets will also fail sooner if the system is hotter, especially the collector gaskets.
If your vehicle is being run on the street or for extended periods of time, you should never wrap headers. Exhaust wraps insulate the exhaust too much and the exhaust temperature is raised to a level that fatigues the header material causing cracks.
Not my info, but definitely something to think about before doing it. I am sending my stainless headers off to be coated with one of the new heat ceramic coatings that are out now. The finished product looks just like polished aluminum.
Old Jul 1, 2002
FamilyMan's Avatar
Thank you SQCivic. All those cons are right on. There is no doubt that the header will probably crack eventually, but I feel that's a worth while trade off. By then there should be some other header out for our cars that actually produces HP. What a great excuse to get a new one. No?
Old Jul 1, 2002
SQCivic's Avatar
We can only hope!
Old Jul 2, 2002
Dupes's Avatar
Dupes is an unknown quantity at this point
nice car man...I'd get a flashier paint job though
Old Jul 3, 2002
jamesbbh's Avatar
yall giv eme youre opinions on why my trunk doesnt look clean. im not bitching i just want to know why so i can fix it
james
Old Jul 6, 2002
TOOLOWCIVIC's Avatar
Looks very clean.
Old Jul 8, 2002
juscallmetoyota's Avatar
juscallmetoyota is an unknown quantity at this point
I'm sorry, but that car is straight up GHETTO! c'mon guys. big *** flip down monitor, WTF? @least get an indash LCD. Engine bay looks like trash, loose wires everywhere. What kinda system is that & don't tell me its CUSTOM. It just looks like a wannab BALLER car.
Thats just my opinion.
Old Jul 8, 2002
Do you even get sound whn you play anything on that monitor?
