OEM Honda Front Camber Kit
Old Jun 25, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
Anyone ever realize Honda sells a front Camber Kit for our cars? I noticed it when I was paging through the tech manual under alignment. They have part numbers and all for the front bolts that you use to adjust camber. Don't have the numbers off hand but anyone with the tech manual (big teal book for 2001) can confirm this. Just another idea for keeping as much oem as possible. Peace
Old Jun 25, 2002
VNlilMAN's Avatar
The Standard One
hmm... must be for their sport suspension package they have..
Old Jun 26, 2002
2cute's Avatar
2cute is an unknown quantity at this point
Your front wheels will not camber.
Old Jun 26, 2002
Brandon's Avatar
Brandon is an unknown quantity at this point
Camber is not a verb. Front and Back wheels CAN have + or - camber.
Old Jun 26, 2002
2cute's Avatar
Yeah ok thank you for the grammer lesson. I knew that. Camber is a noun. Now the question is what does that have to do with the question asked?
Old Jun 26, 2002
OyD's Avatar
OyD
OyD is an unknown quantity at this point
Quote
[hr]Originally posted by: 2cute
Yeah ok thank you for the grammer lesson. I knew that. Camber is a noun. Now the question is what does that have to do with the question asked?[hr]
First part of his response was to correct your grammer
Second part was to correct your misinformation
He most likely didn't want you feeding the guy asking the question wrong info
Old Jun 27, 2002
VNlilMAN's Avatar
The Standard One
imma have to go with 2cute. the change of camber on MacPherson struts is very minimal...
Old Jun 27, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
you can't camber the front wheels your sayin ?? only tha rear?? why is that??
Old Jun 27, 2002
VNlilMAN's Avatar
The Standard One
the camber on the front does change, just not by that much... the back however does, this is due to macpherson struts in the front and double wishbone in the back.
Old Jun 27, 2002
2cute's Avatar
The design of the McPhearson struts does not allow for a change in camber. They will change a little but not enough tp throw you out of spec. In technical terms McPhearson strut: a telescopic member incorporating damping with the wheel rigidly attached at it's lower end, such that the strut maitains the wheel in the camber directon; the upper end is fixed to the body and the lower end is located by linkages which pick up the lateral and longitudinal forces. Also since the McPhearson struts are independant the disturbacne of one wheel does not directly affect the transversely opposite wheel. The rear however is a double wishbone suspension which is a suspension configuration in which an upper and a lower A-arm control and upright hub carrier. Also since there was a question about what camber was it is an inclination of a wheel outward with respect to the body.
Old Jun 27, 2002
VNlilMAN's Avatar
The Standard One
better then how i would have explained it
Old Jun 28, 2002
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
2cute are you an engineer or something? That was quite an explanation. I feel like I have been schooled for the day [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jun 28, 2002
2cute's Avatar
LOL no I have just spent my entire life in a garage. I am one of the few chicks around that knows a lot about cars and is a grease monkey.
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
SneakerPimp
Nov 3, 2001 10:57 AM
ImmortalEX
Oct 31, 2001 10:00 PM
