From looking at my Alignment report (have a pic) , can you tell if I need a camber or another alignm
Old Jun 25, 2002
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
From looking at the report I got back do you think I need a camber kit and or another alignment. To me when I look at this they did a crapy job of doing an alignment. I don't feel any thing wrong but this report keeps on bothering me. I'm running on 215/35/18's with 1.4" drop with sportlines and koni's so I want my alignment to be correct so I don't ware out my tires unevenly. Thanks
Old Jun 25, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
It looks like it didn't change much....[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jun 25, 2002
Mbow's Avatar
YOu look fine to me. Everything seems to be within spec. It is usually only the camber that you have to worry about. I just dropped my sedan with the prokit springs and my rear wheels are sitting at -2.5 degrees.
Old Jun 25, 2002
VNlilMAN's Avatar
The Standard One
after seeing this i guess i wont be getting a camber kit or alignment after all
Old Jul 5, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Per the manual:
Front camber is 0.00 plus or minus.5 degrees
Rear camber is -1.00 plus or minus .5 degrees
I am somewhat perplexed since I used the sportlines and my front was off -.75 degree and -2.00 before the camber kits were installed. The front kit will adjust to one degree plus or minus and the rear will do 3 degrees plus or minus.
Old Jul 5, 2002
VNlilMAN's Avatar
The Standard One
if that is true, looks like it is still in spec even after the drop, guess i wont be getting a camber kit...
Old Jul 5, 2002
maverickja17's Avatar
maverickja17 is an unknown quantity at this point
After I installed my springs I took the car to NTB and got an alignment, no camber kit needed because our cars can correct a lil bit of camber.
Old Jul 5, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
hmmm i wonder im gonna bring my car to a shop like that too and see if i need to install the cambers on the rear
Old Jul 6, 2002
pdxbiker's Avatar
The shop where I got springs installed told me not to get a camber kit because our cars are made to have some positive or negative camber. They told me that our car will handle alot better without a camber kit but you will be wearing out your tires unevenly. They also said that our cars would handle funny with a camber kit. They do recommend a camber kit if you do slam your car since most of the time you are going for show and not as worry about the handling.
Old Jul 6, 2002
alltech01civic's Avatar
White Pony
alltech01civic is an unknown quantity at this point
if you squat behind your car and your tires look like this-------> / \
that's when you know you need a camber......or you can just feel the inside of your tires to see if they are wearing out.....
Old Jul 6, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
Quote
[hr]Originally posted by: pdxbiker
From looking at the report I got back do you think I need a camber kit and or another alignment. To me when I look at this they did a crapy job of doing an alignment. I don't feel any thing wrong but this report keeps on bothering me. I'm running on 215/35/18's with 1.4" drop with sportlines and koni's so I want my alignment to be correct so I don't ware out my tires unevenly. Thanks[hr]
Ha Ha, were did you go to get your alignment done, I bet they really wanted you get a front/rear camber kit, huh? Well, that is my job, I am an "alignment tech". Yeah I recomend you get a front/rear camber kit. If you want the best handling/longest life out of your tires, get a kit. Then get an alingnment. They will probably give you a better job next time too. From your specs you are going to get some wear, you are pushing all of your specs to the max. Make sure you make them get your specs in or as close as possible to the middle of the min/max of specs. They start with the rear toe/camber to get your thrust angle, your's is ok. I could go on and on, but my opinion is that they just want you to get an alignment kit before they put time/better specs on your car. PS either complain and get better specs or get the kit and get the best specs and demand a near optimum specification job after the camber kits.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
TheRiddicles
Sep 21, 2015 01:28 AM
