can LX (14") Civic take EX 15" stock wheels?
Recently, I am replacing alloy wheels on my 2k2 EX. Just wondering if anyone knows a 2k2 LX with 14" factory wheels can take my 15" factory wheels without problems...so that I can give it to my gf...
THANKS
THANKS
it should fit but the speedo might be off..cuz i entered stock size: 185/70R14 and the new size to 195/50R15 and it is a little too fast.
i was going to start a new thread asking the same thing...can anyone answer erikku and my question?
i am thinking getting a set of 02 coupe LX steelies and 15s hub cap then i will go get some 195 or 205/50R15 tires, would my speedo be off???
must use proper tire size to keep accurate reading on the speedometer... 185-70-14 , 185-65-15 , 195-60-15 with this tires you won't have problems with speedometer...
TIRE CALC
TIRE CALC
Quote
[hr]Originally posted by: Macko
Speedo's programmed different? if its true, that is soooo gay.....2k1 LX has 14" 2k2 LX has 15", i doubt it...are the overall size of both these tires the same?[hr]
Basically it will probably be so minor, almost unnoticeable.
You'll get that much difference between a new tire & a used one... I doubt that Honda bothers changing anything for such a slight difference... my vote is: Go ahead & swap'em - it's an improvement.
I plan on doing the same thing. Im puttin 18's on my 2002 ex coupe and puttin the 15's on my wifes 2001 lx 4dr and puttin the 14's in the basement. Come winter I'll reverse the whole process and put the 18's in the basement. Whew! talk about rotating your tires.......
i changed my plan..i picked up a set of used 2003 SiR rubbers and rims from some guy and it will go on my car
here's my question, the SiR stock rubber is Firestone FR690 and the size is 185/65R15
i thought they are wider...but what is the size on the Si (cdn model) or EX (us model)? i thought they have the same rims and same size but i want to confirm with you people
You sure you got 2003 used?
I have 2002 SI rims on my 2001 CIVIC and they are 195/60R15's, very very very very very very very very very minimal difference between my stock 14's and these 15's.
smmahan
Apr 15, 2015 08:17 PM
