HELP@@
Old Jun 21, 2002
civicvtec1ps's Avatar
Search and Learn
HELP@@
i installed INJEN CAI yesterday, but i have problem
when i turn on A/c right bliker turns on and blinks..
ane without A/c on when i use RIGHT blinker , it beats fast!
left blinker is fine.
i dontknow how the he11 i should fix it . do i have to redo intake pipe or what? people told to fix ground? he11..
i need to fix this ! i NEED A/C..
talk to me through AIM - peacemaker1ps if you have it ,
appericiated
and anyone who has INJEN CAI
does battery fit perfect? its kinda tight fit so i had to bend my tie down...
Old Jun 21, 2002
HondaCoupe's Avatar
HondaCoupe is an unknown quantity at this point
i dunno sounds F*cked up, id try seeing what the CIA is touching and see if maybe the AC makes it touch something electrical...
Old Jun 21, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
make sure your ground is tight. There was post about this a while back
Old Jun 21, 2002
bballer50's Avatar
bballer50 is an unknown quantity at this point
I installed my injen CAI about three months ago. And that little bracket thing with the big rubber washer didn't ground my wires very well. So I went to the local hardware store and bought 2 or 3 washers, put them on the big rubber thing, tightened the ground wires to the car and bam! It worked.
And the battery is going to be in a tight spot, don't worry about it, as long as the tie down is holding the battery down you should be fine. Hope this helps
Old Jun 21, 2002
Toretto's Avatar
Toretto is an unknown quantity at this point
u are touching ground to somthing, but i dont think its your intake,
its something else that is electrical, check your light switches....
