great...my dome light doesnt work when the door opens....
Old Jun 12, 2002
angjc3's Avatar
angjc3 is an unknown quantity at this point
I just replaced my interior dome lights...and um..now the front dome light doesnt work when I open the door
that's why I get for DMY
hm...I'm thinking it's a fuse problem...if it is...does anyone know
where the fuse is??
I know there are fuses in the engine bay, but there are fuses under the steering wheel as well
does anyone know exactly which fuse deals the domelights when opening a door??
note: I'm kinda worried now, because the back domelight works, but the front dome light doesnt when I open the door
Old Jun 12, 2002
gurlyspeeddemon's Avatar
gurlyspeeddemon has a spectacular aura aboutgurlyspeeddemon has a spectacular aura aboutgurlyspeeddemon has a spectacular aura about
my dme light doesnt wrk smetimes..........check to make sure the settings r ok ya know....mine eventually started wrkin after awhile
Old Jun 12, 2002
angjc3's Avatar
settings???
Old Jun 12, 2002
blackcivic07's Avatar
blackcivic07 is an unknown quantity at this point
maybe the new bulb is a bad one...
peace [IMG]i/expressions/beer_yum.gif[/IMG]
Old Jun 12, 2002
Macko's Avatar
Macko is an unknown quantity at this point
Fuses are labeled on the panels in the interior fusebox, and for the engine bay it's on the cover... or might simply just be th bulbs
Old Jun 12, 2002
kristy's Avatar
kristy is an unknown quantity at this point
Did ya switch the bulb out again to the orinial one? maybe its the new one ya put in. I changed mine out the other day and had no problems. Haha make sure you didnt do something as dumb as not switchin it to "door" and not "off" or whateva!
Old Jun 13, 2002
angjc3's Avatar
yeah I did that
the bulb works...if I switch to on...it works
but when I put the switch in the middle (only works when you open a door"
then that's where the problem is
the the bulbs works
so....could it be a fuse problem? or do I have to see if the switch connection was somehow damaged when I put in the new piaa dome bulb??
Old Jun 13, 2002
angjc3's Avatar
Quote
[hr]Originally posted by: GurlySpeedDemon
my dme light doesnt wrk smetimes..........check to make sure the settings r ok ya know....mine eventually started wrkin after awhile[hr]
hey gurly.....wow...you're so right!!!
but I'm confused....why are our cars doing that?!
that's so weird.....
Old Jun 19, 2002
2k1coupe's Avatar
2k1coupe is an unknown quantity at this point
Mine doesn't work either when I open the door. And it doesn't dim anymore either. It will turn on when I start the car and the door is open though...
ORskier
May 3, 2015 12:54 PM
darwin-t
Apr 18, 2015 09:29 PM
twtron
Apr 17, 2015 12:09 AM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
