gauge cluster swap????????????????
HISPAnIC CAUSIn PAnIC
yo welcome man if you do a search you will find some info on it probley if you still cant find info on it you can turn on your pm and pm me i will try to find info on it and for further refrence do a search befoe you post a new topic some other members will flame you
sup fellow dx rider. Yea you can swap but I heard that the total milage of the car resets. I emailed my dealer and didnt even respond to this question of mine. those sucka$$. Tell me when you get it done and where you bought the cluster cause i wanna do that also. late
Hey, I also drive a DX, I've already done it...you can see it on my member's ride....it's very easy...any questions...feel free to ask me, either here or PM...and to answer what was asked before...yes, the mileage will read the one on the new cluster...if you get a new cluster, it will read 0 miles, if you get an used one, like I did it will read the last mileage registered...I got mine with a bit more miles than mine, so all I did, was to check the exact mileage it has, then, swap it when the mileage was exact...but that was just me...you can either get a LX or EX gauge cluster, but the EX one will have the ABS light ON forever, so you should cover the LED, by covering it with something just behind the gauge face...
Hey anibal how much was the cluster? did you get it from a junkyard or a dealer? Can you give me the full details like instructions so I can also see the rpm meter go up and down too? thanks late
Hey I also want to have an EX in my DX.
When I heard that it resets the miliage, I said forget it; but it sounds like you(anibal) found a work around.
The main reason is so that I have a tac. I am sick of driving stick with out one.
Any info would be great.
if all you want is a tach, then just change the cluster to an LX, it has a tach. as i understand it, the EX has a higher redline than the DX/LX so if you switch the clusters with an EX you might run the risk of forgetting where your red line is and phucking up your engine if you redline too much. just my $0.02.
is there anything else on the EX cluster that isnt on the DX that makes you want to swap? i dont know...
__________________________________________________ ____________________
Pyro
Member
Tuesday April 02, 2002 1:27:00 PM
Anyone know where i can find these for my 01 Manual trans LX? everything i find is for ex is htere a difference in the gauges?
Su madre duerme con las vacas!
2K1 Civic LX 4-door
5-speed
Nighthawk Black Ext.
DIY Arm Rest
Aim: Oryp
ICQ: 34110552
SOON TO COME:
DIY Side Markers
DIY Lower Grill
DIY Clear Corners
DIY Painted Trim
Report this to a Moderator
Reply Quote Top Bottom Edit
WhosYoDadday85
Diamond Member
Tuesday April 02, 2002 2:29:26 PM
Pyro: From what I recall, there is a differance with the tach part on the gauges...the ex has a higher redline...?
-WhosYoDadday85
ba7genz.com - Official Bay Area 7th Gen Team
__________________________________________________ _________________________
maybe im wrong, but this is what they said...so im just relaying what ive read in the past. heres the link if you want to see...
Other Thread
hope it helps.
Pyro
Member
2K1 Civic LX 4-door
5-speed
DIY Arm Rest
Aim: Oryp
ICQ: 34110552
SOON TO COME:
DIY Side Markers
DIY Lower Grill
DIY Clear Corners
DIY Painted Trim
WhosYoDadday85
Diamond Member
-WhosYoDadday85
Other Thread
hope it helps.
Well come to think of it, there isn't anything special about an EX over a DX for me. I just want the tac.
I sopose that DX has a tac cluster and a non-tac cluster - right?
It's hard to almost redline at every shift if you don't have a tac.
Is anibal going to share?
sorry for the delay...just what you really want to know??? I got it off Ebay...but there's more places where you could get it...
My car RPM cuts off at 7000rpm...which is fine, about 200rpm past the redline....
The only thing about the EX clsuter is the ABS LED light...since we don't have ABS, it will be on forever...so to not see it on everytime, I just covered behind the gauge faces, so it's not noticed. The cluster is pug n'play...just have to take the DX one and plug the LX or EX one...just 2 plugs...the whole process is just 5 screws(2 for the cluster cover, 3 for the cluster), 2 clips of the cluster cover and 2 plugs...no big deal....just be careful when taking out the clips of the cluster cover..
here's a pic of my cluster at night...the ABS light was covered...it's suposed to be to the left of the SRS light...and also included a link to my ride, there's a pic of the cluster during day...
Any question you may have...PM me or reply...
MY RIDE
NEW CLUSTER
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Mvc-115f.jpg (19 Kb)
MY RIDE
NEW CLUSTER
OH yeah can you also order the tach with a certain milage? Probably not right? And also when you remove the two screws for the gauge plastic cover, did you just pull out the black plastic cover and the same with the clear cover? thanks
NO, the black cover comes out alone, the clips are a bit hard to pull, so be carefull no to break it, the clear palstic is part of the cluster...
NO deal...when he was selling the cluster, he specified the mileage it reads, and because mine had lower miles than his, I just bought it and waited until my mileage matched the new cluster. most people on Ebay that sells them apecify the mileage, sometimes it's a bit unaccurate, but close to the mileage they specify...
I have an LX guage cluster if anyone is interested in it. I'll let it go without hurting you too bad. It is out of a sedan, its an automatic, and the milage reading is 34,500 miles. Let me know if anyone is interested. Email me at Turtle.
I wonder that same thing, if the K20A if posibble it will be nice to also have the RSX cluster...more accurate and cool readings... [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Hey, Turtle's offer is very good, much more cheaper than buying a new one, and that's a whole cluster with everything you need...don't let him go...[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
i had to change my ex/si cluster since i am really stupid and grounded the dimmer wire while installing my stereo. no fuses blew! cheap a$$ honda integrated the dimmer switch with the entire dash assembly and i had to replace the whole thing.
anyway, here in canada the sedan cluster is a very light silver, almost white. i was considering a swap but didn't do it. apparently the sedan cluster is in more sub pieces but it still fits. i'm sure the swap will work the other way.
as i was told, keep in mind that clusters are slighly different from 2001 and 2002.
total cost to swap = $600.
mileage reset to 0 = $3,000 savings
thats the only way i'll justify this charge to myself!
If anyone is still interested in the cluster, Ill let it go for $75 shipped. Dont look upon the higher miles as being bad. The only time you would affected by it is if you went if for waranty work and to get it inspected. When you do this just put the factory one back in and youll have your original miles and those will actually be lower than the miles on the car itself.
fatih717171
Jul 25, 2016 06:22 PM
