Air Suspension FAQ (Good)!
Old Jun 3, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
What is the difference between manual and fast bags?
The difference is in the valves. Manual kits use manual pneumatic switches. These switches are slower than electric valves. Manual valves include the gauge, switch, and valve together. This requires the air line to be plumed directly to the switch. The switch assembly would need to be mounted in a place that would allow air to exit the system and all the hoses to be plumed. Air is release direct from the switch.
Electric valves or fast bag valves use electric switches and gauges. The valves can be mounted in any location. The switches and gauges can then be mounted in a suitable location and only need the wires ran from the electric valve. Electric valves can also be used with a remote control, Playstation style controller, or 10-switch pre-wired box allowing for seesaw, all up, all down, etc., with a flip of the switch.
What are air struts or strut bags?
Most front wheel drive cars use McPherson struts. Most struts are a combination shock and coil spring. Air struts are the same except the coil spring has been replaced with an air bag. This allows the McPherson strut equipped car to have the capabilities of the air bag suspension.
Are air bag suspension reliable?
Yes. If installed and maintained properly, an air bag suspension system will last as long as any other suspension component.
I heard strut bags can twist and bust. Is this true?
While it is true that early strut bag systems where not very good, today's air struts are much better. The new air strut systems will turn with the strut assembly and not bind up.
What do the air bags replace?
On most vehicles the air bags completely replace the springs and shocks. Some vehicles can still use their shocks.
What are air cylinders or air rods?
Air cylinders where designed for vehicles that may not have a place large enough to mounts an air bag. Hondas need to use air cylinders because the strut tower is not wide enough to use an air bag.
How is the ride quality?
It depends on your vehicle. If you are using really low profile tires or no shocks, you could have a rough ride. Most ride problems are from not having enough air in the bags. If the ride quality is poor, just put more air in the bag.
Air cylinders will ride rough. If you have air cylinders and are experience a rough ride, install a set of air accumulators. That will help your ride.
What are air accumulators and how do they work?
The problem with air cylinders is that they do not have any give like bags. When you hit a bump the air has no place to go. Air accumulators give the air a place to go. When you hit a bump, the air goes from the cylinder to the accumulator. The air then returns from the accumulator back into the cylinder when you are driving normal. The accumulator also is filled with nitrogen gas like a shock. This allows the accumulator to give a smoother ride.
Old Jun 3, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
thanks that was very informative
Old Jun 3, 2002
Spider883's Avatar
9K Redline Owns U
great info
making sticky
Old Jun 4, 2002
Thanks. I was surfing the net for info on air suspension, and I found it. Great addition to the "general" FAQ if you ask me[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Jun 5, 2002
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Thanks,
Very informative.
Old Jun 6, 2002
TOOLOWCIVIC's Avatar
Are you planning on getting airsuspension? That is what I'm trying to get but CIVICONBAGS says he has airbags and his cars ride quality sucks. I am waiting to see if one day I get an a car with airsuspension and see how it rides.
Old Jun 7, 2002
VNlilMAN's Avatar
The Standard One
the ride quality depends on how you 'tune' it. not sure but heard the lincoln town car was on bags, if it is that ish rides nice...
Old Jun 11, 2002
If you have airbags not airrods can you still put air accumulators?
Old Jun 11, 2002
I dont know TOOLOW....
From my understanding, I think that air accumulators only go with air rods because the air has no where else to go where as with bags, the air can move and and such......
Old Jul 20, 2002
Well I saw a 2k2 civic on airbags. I asked him if they were bags or rods and he told me bags. When he was driving his car looked as if it had blown shocks. It was too bouncy. I went to the place where he said he got them installed and the guy there told me that the airbag kit had just came out for the 7thgen and that the car I saw was the first to have it. I forgot to ask him what company made it but he told me that if I got the kit it would ride better than factory. From what I saw it was bouncy. Now I am having second thoughts on airsuspension. BTW he quoted me $2600 total installed. They were actually airbags with a strut.
Old Jul 20, 2002
VNlilMAN's Avatar
The Standard One
its probably the one made from chassis tech... they use 'air struts'.
Old Jul 20, 2002
Well civicpunker ordered that kit. I am going to wait to see what he has to say about it and how it compares to his old suspension setup.
Old Jul 27, 2002
errorr's Avatar
errorr is an unknown quantity at this point
got cylinders on my prelude it rides better then factory. Ride quality depends on if its a FBSS system or a FB system size of line u are running and the cylinder quality. got mine from www.the-hack-shack.com 1 year ago. I wouldnt suggest their kit anymore its to massed produced now. CLICK TO SEE PICS thats my lude sits low dont crack my kit or nething any more got a civic for daily tho [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 27, 2002
Hey error, why would it matter if its fb or fbss. Shouldn't it ride the same? I heard bags ride better than cylinders. So if I get the bags or airstruts for my car it should ride good enough for a daily driven car? Do you have accumulators on you car.
Old Jul 28, 2002
VNlilMAN's Avatar
The Standard One
damn your lude looks pretty phat... and i think hack shack uses air cylinders from eai.
Old Jul 29, 2002
errorr's Avatar
ok first of all bags on FWD doesnt work to well. Sturt bags give u know drop and ride like booty. U need shocks with bags or it will give u a horrible ride. I have no accumulators it rides fine. Bags pop and go bad cylinders last for years if not abused. cylinders are faster and full bolt on. EAI and hackshack are the same thing.
Old Jul 29, 2002
VNlilMAN's Avatar
The Standard One
how does air cylinders actually bolt on the car? cause i know with an airstrut that replaces both the shock and spring... from my understanding air cylinders go INSIDE the spring??? or do air cylinders replace both spring and shock as well? if it does go inside the spring, the spring limits the lowest ride height right? meaning you would have to get really really low springs in order to slam the car. this just doesnt sound right to me but also it replacing both spring/shock doesnt sound right either.
Old Jul 30, 2002
The cars I have seen with air cylinders just have air cylinders. It replaces both the shock and the strut. The kit that I saw on the white civic in my town had airbags with a strut. He said AIM made the kit and that it just came out for our cars.
Old Jul 30, 2002
VNlilMAN's Avatar
The Standard One
if it replaces both shock and spring then does it come with that arm that hooks up to the tie rod? or would we somehow have to hack our stock struts in order to put those on our car? that other guy did say it was just a bolt on installation so hacking the struts wouldnt make it a bolt on...
Old Jul 31, 2002
errorr's Avatar
well prelude is double wishbone. Ive been to a shop where they were installing air on a GS400 and he had to hack up the struts. Dont buy from AIM their fittings are really bad and so are their cylinders. But i think if you go with the strutbags u dont have to hack up the struts. But i think they have started making brackets for MC Phearson sturts full bolt on cylinders.
Old Jul 31, 2002
Hey error, so how is the ride with the cylinders without accumulators? Is it bouncy like hydros or what? Is it good for everyday driving and do you think it rides better than with Konis and Ground Control? That is what I currently have.
BTW what did you pay for your setup?
Old Jul 31, 2002
errorr's Avatar
Dude it rides better then my 02 civic. thing is so bouncy its a dream when i drive the lude too a show. i got my setup 1 year ago for 1500 shipped then i upgraded to a Viair 450 100% duty compressor, 10 switch box, and another 5 gallon tank. so over all id say like 1800 for the setup. Did the install my self in 1 day as well as 2 other Hondas i have bagged. Havent done a new civic yet havent been asked to either. Hydros have no give, air gives, hence making a softer smoother ride.
Old Aug 1, 2002
If it rides as smooth as you say it does then I will eventually get them.
Old Aug 27, 2002
Jiggles's Avatar
Jiggles is an unknown quantity at this point
Nice and informative. ThankGod I have coilovers. Airbags seem like too much to maintain. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Sep 18, 2002
7thgencivic's Avatar
7thgencivic is an unknown quantity at this point
cool
Old Sep 28, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
so what kind of 'maintenance' is involved with airbags? I'm considering an air ride to replace my B+Gs
Old Sep 28, 2002
VNlilMAN's Avatar
The Standard One
i would think there isnt any maintnence such as greasing things or anything like that. but as with everything i'm sure things fall apart or break every now n then. but ya for the most part, it should last just as long as the car would last...
Old Oct 3, 2002
WeSSoN's Avatar
WeSSoN is an unknown quantity at this point
I GOT ONE THING TO SAY..............SCREW AIR....GET HYDROZ My Buddies Accord on DroZ...
Old Oct 3, 2002
VNlilMAN's Avatar
The Standard One
trunk
uh.. i think i'll stick with air. but why do you say hydro's better?
Old Oct 8, 2002
TRIPLExRATED's Avatar
TRIPLExRATED is an unknown quantity at this point
Hope this helps anyone who wants to get air rides for their car. Just this past weekend I watched a shop called Ultimate Auto Boutique(sp) www.uabcustomcars.com install some air rides on a 2k1 2dr civic. The kit came from hack shack and retails around $2500. The kit includes rods for the front and bags for the rear, 3 gallon tank, 10 switch box, and the smallest compressor. This kit is a front, back, side to side kit. Like people have been saying this is a McPherrison Strut (sp) and does use rods in the front and bags for the rear. The install took about 3 days but it can take up to 13hrs if you dont want to take a break. When the kit was finally installed we wanted to see how low it would rest. The rear of the car was tucking the 17's and the front was still high, if you have coilovers and put them all the way down depending on the coilovers, thats how high the front is, about a finger gap in the front. The kit rides like a caddy and as posted before the kit looks like it has blown shock, thats only the back because it is on bags in the rear, the rods dont ride like that. There is talk about modifying he front rods to go lower but that is gonna take some time and I will post up if I hear anything. If anyone has any qestions about this set up call Ultimate Auto Boutique(sp) their number is on their site and ask for Brooks, he is the one who did the install. Tell him twin sent you.
