Mystery brake fluid loss
Old Nov 4, 2022
blackdog48's Avatar
blackdog48 is an unknown quantity at this point
Hi,
I had been experiencing a loss of brake fluid from my master cylinder reservoir for a while. So, two weeks ago, I had my mechanic look things over and he replaced a brake line that he said was leaking. Today, I got in my car and the brake indicator light had come on again. I checked the resorvoir and it was low . So, I pulled the brake line covers (guards) off and my dad looked at the lines while I pushed the brake pedal. No apparent leak. Also, I pulled all four wheels (looking inside the drums in the rear), and also no apparent leaks. And, there is nothing evident under the hood at the master cylinder or inside the car near the firewall that I can see. Do you all have any ideas on why the reservoir is still losing fluid? Thanks a lot,
blackdog48
P.S. One other brake line is pretty rusty, so I will replace it, but even it did not leak during our tests.
Old Nov 5, 2022
Colin42's Avatar
Re: Mystery brake fluid loss
Did you check under the dust seals in the wheel cylinders? Master leaking into the car at the firewall?
Old Nov 5, 2022
blackdog48's Avatar
Hi Colin42,
There is no dampness below or within the brake cylinders (I peeled back the rubber boots to check inside them). How would I determine if the master cylinder is leaking into th firewall area? Thank you,
blackdog48
Old Nov 5, 2022
blackdog48's Avatar
Can you tell me what this gizmo is? Is has an empty length of line running to it that runs along with the brake lines to the rear. This component is under a little plastic guard right near the front left edge of the gas tank.
blackdog48
Old Nov 5, 2022
Colin42's Avatar
Originally Posted by blackdog48
Hi Colin42,
blackdog48
Stick your head under the dash and look.
blackdog48
Not brake related, something evap related
califcamper
Apr 23, 2018 10:53 AM
Instrument48
Sep 9, 2013 08:23 AM
scottroll
Jun 27, 2012 09:50 PM
em2maxamillian
Brakes
Oct 1, 2011 01:25 PM
civicdude
Brakes
Nov 21, 2001 08:00 PM
