Is "INJ" fuse for fuel injectors in 2013 Civic?
Old Oct 21, 2022
niemand's Avatar
niemand is an unknown quantity at this point
What is the "INJ" fuse in the engine compartment fuse box? The fuse is 15 A, and they put it inside parentheses: "(15 A)". What's the meaning of using parentheses? I'm trying to disable fuel injectors.
Old Oct 21, 2022
FRSam's Avatar
Click Here
Re: Is "INJ" fuse for fuel injectors in 2013 Civic?
What are you trying to do? Compression test?
Old Oct 21, 2022
niemand's Avatar
Yes.
Old Oct 22, 2022
FRSam's Avatar
Click Here
Originally Posted by niemand
Yes.
Just remove all the spark plugs. It won’t run with just the compression tester in.
Old Oct 25, 2022
niemand's Avatar
But the fuel injectors would still spray fuel into the cylinder with every turn of the key.
Old Oct 25, 2022
FRSam's Avatar
Click Here
Which is fine.
Old Oct 25, 2022
niemand's Avatar
Which is fine.
Wouldn't that dilute the engine oil in the crankcase? Would that fuel clean the rings, and unstick any stuck rings?
Old Oct 25, 2022
Colin42's Avatar
The little bit you'll get from doing the compression test won't make much of a difference. Pull the fuse if you're really that concerned.
rob-
Apr 18, 2010 07:07 PM
taly
May 15, 2009 02:26 PM
blinger
Aug 29, 2008 08:13 PM
midnightblueEX
May 18, 2005 10:42 PM
diggaflip
Lighting
Mar 2, 2005 04:19 PM
