Are camber kits needed along with coilovers inorder to drop your Car?
Old May 29, 2002
Bijutsuka's Avatar
Bijutsuka is an unknown quantity at this point
I heard that in order to drop your car you must buy a front and rear camber kit. is this true? I thought you just had to maybe buy new springs and coilovers to drop it a couple of inches and that s it. Whats up with this. Is it really needed?
- Domo Arigato-
Old May 29, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
You need a camber kit to adjust your alignment. Once you lower your car, your wheels will have more negative camber (tilted inward) and the insides of your tires will wear out faster. It is advisable to get an alignment done each time you adjust your coilovers.
A camber kit is highly recommended, but it's not absolutely necessary. You can still lower your car w/o a camber kit, you just won't be able to realign it correctly.
Old Jun 4, 2002
CivicSense's Avatar
CivicSense is an unknown quantity at this point
What if you lower your car with springs and decide not to install a camber kit but instead just get the wheels aligned properly after installation of the springs. Would the tires still eventually not be aligned and continue to wear on the insides of the tires?
Thanks
Myredjonda
Apr 14, 2015 07:00 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
SneakerPimp
Nov 3, 2001 10:57 AM
ImmortalEX
Oct 31, 2001 10:00 PM
