Transmission swap post information/Questions about automatic to Manual Transmission swaps
will not rev past 4k engine/trans swap
Old Feb 28, 2022
NormalCivicGuy's Avatar
NormalCivicGuy is an unknown quantity at this point
Question will not rev past 4k engine/trans swap
I also got a question I have a manual swap with a manual ecu and a vtec manual harness only downside( my engine was a d17 non vtec) Is im limited to 4k rpm I still have my auto engine non vtec will i be able to do it or will I need a manual non vtec harness
Old Feb 28, 2022
Re: will not rev past 4k engine/trans swap
you should have a CEL on, read the code
Old Feb 28, 2022
Yes it because my car I just finish the auto to manual swap I bought a donor car had a d17a2 harness which I use also with the ecu I just want to know if I can use my auto d17 harness with the manual ecu
Old Feb 28, 2022
clarify:
  1. old engine
  2. new engine
  3. did you swap engine or not?
Old Feb 28, 2022
No the engine was not swap at all just the transmission
Old Feb 28, 2022
ok, was confused since you said "was non-VTEC"
If you are using a VTEC ECU on a non-VTEC engine, the ECU will try to find the VTEC, but not there, thus it will go into limp mode (RPM restricted)
an auto ECU will try to find an auto trans, might trigger a CEL
girhed1234
Apr 27, 2021 05:58 PM
Dameancharles
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 19, 2019 01:03 AM
Linkage
Transmission swap
Apr 5, 2019 10:44 AM
Dewaholic
May 3, 2010 01:46 PM
msbastien
Oct 20, 2009 06:43 AM
