instructions on how to install black lights in your car
Old May 28, 2002
angjc3's Avatar
angjc3 is an unknown quantity at this point
okay, tell me if this is straight, I plan on installing black lights in the front and passenger seats so when I drive I can turn them on and I wont be that bored
so what I've bought are these
1. switch (I'm gonna be putting this on the extra opened slot beside the lighter socket and the foglight switch)
2. red and black wire
3. lite glow 9" thin light (compliments of target for $24.99)
instructions
- you'll have to take off the center console
- you'll have to take off the middle console so you can get behind and push the extra opened slot
- next you'll want to split the 12V wire that is connected to the 12 volt socket (here you'll split it with the lite glow's wire, and yes I cut off the head of the black lights)
- then you'll use the "red and black wire" to connect to the switch
- use the "extra opened slot" for the switch
- put everything back together
I'm placing the to neon rods horizontally under the glove compartment and on the "under the steering wheel" cover
are these instructions correct? if not, tell me!!!
so I can do it right the first time
oh and I'm doing it cause I've always wanted black lights, and it gives the passenger something to look at while I'm driving =)
Old May 28, 2002
WhiteRabbit's Avatar
you dont need to take out your center console, JUST the panel where the cig lighter is. you can tap into that pos and neg and put teh switch wherever youwant.
then run all teh cables behind your panels, easy to do, and voila. done.
Old May 28, 2002
crazyjetskier's Avatar
crazyjetskier is an unknown quantity at this point
i did mine like that cept i didnt connect it to the 12volt i hard wired to the battery with 30 amp fuse stuck 2 black lights a little smaller than 9 inches in the ceiling one infront, behind the map light, one in back behind the map light.
Old May 28, 2002
angjc3's Avatar
ah I see. yeah whoops, you dont have to take out the center console
hey...so splitting the 12volt wire in the back....that's a good idea?? =)
I cant image running a wire all the way back to the battery, that's way too much work for someone lazy as I am
Old May 29, 2002
its way fine.
Old May 29, 2002
angjc3's Avatar
okay....so if you DO wire via your 12 volt socket
are you still allowed to use the 12 volt socket at the same time??
someone told me that it's not advisable
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
15
Aug 19, 2015 03:12 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
AZ2K1Civic
Oct 27, 2001 10:24 PM
