General information on 7th gen Civic Hybrid
up-to-date info can be found in the link below
https://en.wikipedia.org/wiki/Honda_Civic_Hybrid
The following is a list of its technical features:[5][6][7]
Design
The first generation of the Honda Civic Hybrid was based on the seventh generation Honda Civic. It was the first mainstream vehicle from Honda equipped with a gasoline-electric hybrid system and became the second hybrid model of the company after Insight. Model with manual transmission was rated city 46 mpg‑US (5.1 L/100 km; 55 mpg‑imp) / highway 51 mpg‑US (4.6 L/100 km; 61 mpg‑imp) according to United States Environmental Protection Agency (EPA) fuel mileage estimates,[3] about the same combined mileage as for the Toyota Prius, and became the most fuel-efficient five-passenger sedan ever sold in North America at the time.[4]The following is a list of its technical features:[5][6][7]
- Twin spark plugs light the lean fuel-air mixtures sent to the two-valve combustion chambers.
- 1.3-litre single overhead cam i-DSI lean-burn internal combustion engine with VTEC Cylinder Cut-off System, which allows three cylinders to deactivate during deceleration. The engine generates 85 hp (63 kW) at 5,700 rpm and 87 lb⋅ft (118 N⋅m) of torque at 3,300 rpm.
- Idle stop - when stopped at a traffic light, the engine shuts off automatically, then restarts immediately when the driver takes their foot off the brake, contributing to both greater fuel efficiency and lower emissions.
- 10 kW (13 hp) brushless, permanent magnet assist motor, which functions as a generator during deceleration recharging the battery (regenerative braking).
- Combined output of both engine and electric motor is 93 hp (69 kW) at 5,700 rpm. Maximum torque is rated 116 lb⋅ft (157 N⋅m) at 1,500 rpm for manual transmission models and 105 lb⋅ft (142 N⋅m) at 3,000 rpm for CVT models.
- 144 V Nickel-metal hydride batteries with 6.0 Ah capacity.
- Honda Multimatic S continuously variable transmission or 5-speed manual transmission.
- ULEV or AT-PZEV certification by the California Air Resources Board (CARB).
- Low rolling resistance tires (P185/70R14) on aluminum wheels and regenerative braking.
- Electric power-steering.
sdaidoji
Mar 12, 2021 03:18 PM
Stigs
Oct 1, 2006 08:35 AM
