magnaflow exhaust leak (magnaflow owners)
Old May 26, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
Just installed my exhaust yesterday and I have one exhaust leak right at the first clamp comming back from the exhaust down pipe. I tryed turning the pipes and clamps but that didnt help. Anyone have any ideas, or should I just go get it welded?
Old May 26, 2002
Mbow's Avatar
I had the same problem. The pipes have to fit straight into each other perfectly. If either one is sitting slightly at an angle the u-bolts won't seal the connection. I broke a u-bolt because I over-tightened it trying to get rid of the leak. When that happened, I cursed and said f-it, I am taking it to get welded. While the car was up on the rack, I could hear one of the other connections leaking ever so slightly. My system is welded at 2 of the 3 connections. The connection behind the cat was fine.
Old May 26, 2002
R3DF0G's Avatar
R3DF0G is an unknown quantity at this point
Yeah that was the biggest pain in the *** for me. I had to slide the midpipe a little further forward, then check to make sure none of the connections were exposed, then tighten the hell out of those clamps. Still hangs a little low, but I can live with that.[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old May 26, 2002
Jeff's Avatar
hehe nice to know im not the only one with this problem =) I was starting to get mad because when ever I move the 2nd pipe towards the front of the car then the 2nd clamp would leak, and vice versia. Very nice exhaust though.
Old Jun 12, 2002
Rice's Avatar
Rice is an unknown quantity at this point
My exhaust is leaking too !@#!
the back 2 clamps are
what is the bad part about leaking exhaust????
Old Jun 12, 2002
angjc3's Avatar
angjc3 is an unknown quantity at this point
question.....is the DIY just for Magnaflow Exhaust??
or will it work for any other exhaust??
who from this thread's selling Magnaflow Exhaust??
is it just the muffler?
does anyone recommend something else?
(not too loud..I like it subtle, but not subtle)
Old Jun 12, 2002
Mbow's Avatar
The exhaust system is one the easiest things to do yourself imo. You have 3 bolts behind the cat and 2 where the midpipe connects to the muffler. Jack the car up, slide under with a can of wd-40 or liquid wrench, spray the bolts liberally, wait about 10mins or so, and then take the bolts off and remove the oe exhaust. You won't have any problem installing the new system after taking off the oe.
Old Jun 12, 2002
Mbow's Avatar
Old Jun 12, 2002
2k1Miami's Avatar
2k1Miami is an unknown quantity at this point
How do you know if is leaking? Can you hear it?
Old Jun 12, 2002
R3DF0G's Avatar
Quote
[hr]How do you know if is leaking? Can you hear it?[hr]
yep...think of the riciest exhaust you've ever heard - that's the sound a leak makes.
Reverb2005
Jun 26, 2015 06:22 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
ayzan
24
Apr 17, 2002 06:55 PM
silvervtec01
Dec 9, 2001 08:50 PM
Lightman
Nov 10, 2001 06:44 PM
