Bec Tec *PICS* HERE
Old May 23, 2002
mike's Avatar
mike is an unknown quantity at this point
Bec Tec *PICS* HERE
Refer to the following thread: http://www.2k1civic.com/forum/messag...threadid=35164
Old May 24, 2002
strutwizard's Avatar
strutwizard is an unknown quantity at this point
Thanks Mike, that should do the job.
thanks, again Tom
Old May 24, 2002
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
strutwizard
Please see my reply in the other thread
Old May 24, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
WHOA!! Nice...maybe there's hope for our cars yet[IMG]i/expressions/laugh2.gif[/IMG]
Old May 24, 2002
2k2civic's Avatar
Won't these things act like coilovers since you have an adjustable perch that the springs sit on?
Old May 24, 2002
TOOLOWCIVIC's Avatar
Will the ride be bouncy?
Old May 24, 2002
Will it ride better than with the Konis?
Old May 24, 2002
I had "shorty" dampers and springs on my old Jetta: Eibach springs and Spax dampers...the ride was actually better than stock: no body lean, no bouncyness, just firm and controlled
I'd venture to say, w/o having tried them of course, that these are probably the best solution yet for our cars...especially since 7th gen civics are lighter than most similar size cars.
Old May 24, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
so how do we get them who do we email / talk to?
i wanna see the warrantee and all that
droping my car is the next task so i'm saving up as we speak.....hook me up with some more info on those
Old May 25, 2002
HeRbaLuS, you should check out the thread link in the very first post...Strutwizard answers a lot of questions and explains the merits of the shorty struts vs. stock ones w/ lowering springs
Old May 25, 2002
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
I think I got in a little late on this. Is this a new adjustable from "strutwizard" I guess? Will these be compatible with ground controls?
Old May 25, 2002
Yes, THis is a new shortened ride height adjustable coilover that uses most standard lowering springs.
Slip on sleeve kits are not required with this system.
Old May 25, 2002
<< Won't these things act like coilovers since you have an adjustable perch that the springs sit on? >>
Yes, they do act just like true coilovers not the slip on sleeve type.
Old May 25, 2002
HeRbaLuS's Avatar
hmm so how low can u go without blowing them??
Old May 25, 2002
<< Will the ride be bouncy? >>
Ride quality is one of the main reason that I design shortened ride height adjustable struts because lowered cars don't have to ride like "Tanks"
Lower center of gravity and increase spring rate and up-graded valving equate to smooth ride and greatly improved handling.
Old May 25, 2002
<< Will it ride better than with the Konis? >>
From the members it sound like the koni's are bottom out, the Bec-tech's are not.
Old May 25, 2002
mohawkboom's Avatar
Strut Wizard. Where are you from?
Old May 25, 2002
<< so how do we get them who do we email / talk to?
Here is the email address.
tobuybectecs@cs.com
Old May 25, 2002
<< Strut Wizard. Where are you from? >>
Victorville, Ca
Old May 25, 2002
mohawkboom's Avatar
Companies based out of Toronto, Canada though?
Old May 25, 2002
<< hmm so how low can u go without blowing them?? >>
The tires will tucken under the fender before you can think about blowing out the strut. I have been using this type of strut technology for over 12 years.
The strut works like the factory setup, bottom out is not part of the design.
Old May 25, 2002
HeRbaLuS's Avatar
damn i never hear of this type of suspension before...hmmm
sounds like such a good invention......if these are as good as it seems you are gonna be a happy man in a couple of months.
Old May 25, 2002
RESIDENT ROTOR HEAD
Victorville, Ca
Hey I'm from vegas. Do you have any plans on coming up here at all? If you do I'd like to meet with you and take a look at your product...
Old May 25, 2002
FURY's Avatar
FURY is an unknown quantity at this point
Wait...so if we get these, do we have to get lowering springs as well or could the stock ones be used?
Old May 25, 2002
STYLIN2K2's Avatar
STYLIN2K2 is an unknown quantity at this point
Will they work with the ebach springs that come with the ground control?
Old May 25, 2002
<< Wait...so if we get these, do we have to get lowering springs as well or could the stock ones be used? >>
If you want to lower the car only to lower and not change the handling very much than you can use the stock springs. Using lowering springs will give you more of a drop and improve the handling much better than using the stock springs.
Old May 25, 2002
<< Will they work with the ebach springs that come with the ground control? >>
Sorry but I designed the strut to work with full diameter springs like the car was designed to have on it.
Old May 25, 2002
<< Companies based out of Toronto, Canada though? >>
What do you mean by company based in Toronto
Old May 26, 2002
mohawkboom's Avatar
Yes, they will fit the 2001 civic direct bolt in.
thanks
I make them, I designed them and manufacture them in Ontario,Ca
Company is Bec-Tech Design
My Bad.. Ontario Calif?
Old May 26, 2002
HondaUSDM's Avatar
HondaUSDM is an unknown quantity at this point
is this the same tom w/the bad rep on Purehonda and hondasociety?
