ECU Wiring Harness Layout Question
Does anyone have a chart with the layout of the wires in the ECU's wiring harnesses? Im trying to locate the o2 sensor signal input wire to install an electronic A/F ratio gauge. I do not want to run the wire in to the engine bay and splice in to the o2 sensor, i want to tap directly in to the wire that is in-bound to the ECU. All help and diagrams will be very helpful.
It is the white wire
Connector "A" This is a grey connector.
Pin 6
1---2---3---4---5---6---7/--------/8---9 >top of the connector. Please note there is a space between 7 and 8; 24 and 25; 26 and 27
10/11/12/13/14/15/16/17/18/19/20/21
22/23/24/---/25/26/---/27/28/29/30/31
Here is the layout of the connector
Pin 6
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Jon-Ohio
Jun 30, 2018 08:10 PM
01civyv3
Jun 2, 2015 05:21 AM
davidpaustin
Apr 30, 2015 11:20 PM
