Blower motor resistor
I have a 2002 Ep3 honda civic. My AC isn't blowing air. I've replaced the motor and checked the fuses. I'm trying to locate my blower motor resistor and cant find it. Could anybody assist with a picture of showing where it's located?
Re: Blower motor resistor
It's not a true blower resistor, it's called a power transistor.
A resistor would be used for 4 fan speeds....this transistor is used to control variable speed.
EDIT: On a hatch SI, the part is essentially the same but may be located a bit higher than the one shown in the video. You might need to get the glovebox to open up all the way to the floor then search through that opening, to find the power transistor.
Video is bad for my sanity. Here's a few reasons:
The guy in the video is incorrect @1:19, the power transistor controls the ground circuit for the HVAC blower fan motor.
@1:30 he is showing the diagram of a radiator fan motor, which has nothing to do with the interior fan.
(I have access to the exact same diagrams)
Nowhere in this video does he show the correct wiring diagram for the HVAC blower motor he is working on, yet he somehow manages to stumble into the correct wires to jump to make the fan run.
I think he was more concerned with making the video about a problem he had already figured out, than getting the "trivial details" correct.
For future reference to anyone replacing this unit i bought a new generic unit and connected up the plug to check it was working before fitting everything back together as it was very fiddly.The new unit would only work the fan on high setting.
After many hours of reading and faulting finding i was still scratching my head.
Turns out the heatsink(metal case) of the fan blower motor was touching ground so the fan would only work on one setting.So you are 100% correct the unit has to be fitted in place before testing.
The reason we say it has to be installed in the housing is to keep that huge heat sink cooled by the fans airflow while it runs. That keeps the power transistor inside from overheating and opening the TCO (thermal cut out fuse)
I repaired the old TCO after reading the forum and testing it with a multimeter,soldered a piece of fuse wire in.
Plugged the repaired TCO in to the loom which is really tight and the fan would run max speed only no control, purchased a new generic blower motor and fault was the same.
To cut a long story short i pulled the unit away from the chassis and away she goes
