Blower Motor Quit
Old Dec 1, 2016
mikey1's Avatar
Blower Motor Quit
my heater/fan/blower motor all of a sudden died, does not work at all on any fan setting,
tested #12 40 amp fuse under the hood (heater motor)
tested #14 10 amp fuse under dash
both these test good,
where do i go from here?
should i try hooking the fan up directly to the battery?
Old Dec 1, 2016
Re: Blower Motor Quit
Beat on the bottom of the blower motor...no change?
Blower power transistor? The usual culprit.
Craig will say to watch the fan blade when you turn it on, see if it barely turns. (I still haven't checked this on a bad one)
Get out your $3 test light.....
Test for power and ground at the blower motor. If you have power on both sides of the motor then it's missing the ground, which should be supplied by the transistor. There's more checks you can do from there, but at that point I just plug in another because I have test units and its quicker.
Old Dec 2, 2016
mikey1's Avatar
yeah thats what i was thinking,
i guess i will pull it and test it out
Old Dec 2, 2016
CraigW's Avatar
Try inspecting the fan blades to watch for slight/brief movement when key 1st turned to II, with then fan switch set to on.
If it does move..... then the TCO on transistor is open.
Old Dec 2, 2016
mikey1's Avatar
thanks,
when i get a chance to look at it next i think i am going to jump the pins in the transistor to bypass it and make sure the blower works first, if i jump pins 2 and 4 on that connector i think the blower should run when i turn the key on
Old Dec 2, 2016
mikey1's Avatar
thanks all,
shorted pins 2 and 4 on the transistor connector, turned the key on and the blower ran perfectly fine, so that was an obvious indication the problem is the transistor, i will replace it
Old Dec 3, 2016
CraigW's Avatar
Make sure you have it mounted into place before testing.
Old Dec 4, 2016
mikey1's Avatar
yeah i will,
for now i have done a "poor mans fix" because i had the parts on hand, i have temporarily run two wires from the 4 pin connector out to the shifter area and hooked the wires up to a toggle switch,
this at least lets me turn the blower on and off (highest speed only),
doesn't look so great but will get me by till i get a chance to get the part, can't really drive too well here right now without the defroster going,
Old Dec 5, 2016
CraigW's Avatar
If the TCO IS open, you could grab one pretty cheap and repair your transistor.
Old Dec 5, 2016
^ I have test units with a regular car fuse jumpered in place of the open TCO.
Old Dec 5, 2016
mikey1's Avatar
any pics of this?
i thought about soldering a resistor between the 2 posts?
Old Dec 5, 2016
Originally Posted by mikey1
any pics of this?
The TCO is a fuse, not a resistor.
IDK if a resistor would make it work, and what value resistor are you thinking you would use?
I just soldered a couple lengths of wire to the TCO terminals and connected a regular ATO fuse to those (spade terminals crimped on the wires), like a 10 amp or something handy. Fuse is hanging out the side of the assembly.
I only use it for testing though, I'm not running the fan full time with it that way.
For that matter, you could just jump the TCO with a plain wire for testing. Paper clip.
Old Dec 6, 2016
mikey1's Avatar
thinking 1ohm.....i saw this.....
http://honda-tech.com/forums/honda-c...istor-2041582/
Old Dec 6, 2016
This is now a test unit:
