Weird Coolant leak. I have some pics attached.
Old Oct 30, 2016
AndrewCarpenter's Avatar
AndrewCarpenter is an unknown quantity at this point
Leaking only when the revs get around 3 grand? Oil is fine but im just lost. Cant tell where its exactly coming from but the route it has taken is coming off of that plastic above the oil filter. 2004 civic 450k miles. 5speed lx.
Old Oct 30, 2016
Wankenstein's Avatar
Re: Weird Coolant leak. I have some pics attached.
Have you removed the air box and air intake hose and inspected from the top? Could be as simple as a coolant or heater hose leak. Possibly the water outlet O-ring or seal.
Do a coolant pressure test while engine cold.
Old Oct 30, 2016
mikey1's Avatar
could be heater core hoses
Old Oct 31, 2016
Redneck_cdn's Avatar
Redneck_cdn will become famous soon enough
there is a coolant transfer pipe runs across the back of the motor from the back side of the water pump around to the front PS near the thermostat. I had to replace mine when I had the head off as the pipe had heavy rust on it and was easier to replace with the head off. Was only ~ $50 from stealer.
Gotta love the road salt
Old Oct 31, 2016
mikey1's Avatar
would you rather be skidding off the road and hitting every ditch, curb, and hydro poll in sight?
Old Oct 31, 2016
Colin42's Avatar
Sand > Salt
