Weird Coolant leak. I have some pics attached.
Leaking only when the revs get around 3 grand? Oil is fine but im just lost. Cant tell where its exactly coming from but the route it has taken is coming off of that plastic above the oil filter. 2004 civic 450k miles. 5speed lx.
Re: Weird Coolant leak. I have some pics attached.
Have you removed the air box and air intake hose and inspected from the top? Could be as simple as a coolant or heater hose leak. Possibly the water outlet O-ring or seal.
Do a coolant pressure test while engine cold.
there is a coolant transfer pipe runs across the back of the motor from the back side of the water pump around to the front PS near the thermostat. I had to replace mine when I had the head off as the pipe had heavy rust on it and was easier to replace with the head off. Was only ~ $50 from stealer.
Gotta love the road salt
