Did I short my alternator?
Old Jun 14, 2016
Tz779's Avatar
Tz779 is an unknown quantity at this point
Honda peeps,
I took on the job of replacing the head gasket on my daughters 2001 civic, and while disconnecting the wire to the power terminal of the alternator, there was a spark. Yes, I forgot to take ground battery ��. Now, everything reassembled, oil changed, new coolant, I have no power to anything. The battery is new, showing 12v, but not even interior lights or door buzzer comes on. I have 12v at the fuse box under the hood, but no power to the live terminal of the alternator, key fully turned on. Where do I start? 40 amp fuse for alt is ok. Checked and cleaned ground wire. Thanks so much!
Robin
Old Jun 14, 2016
Re: Did I short my alternator?
Open the fusebox lid, find the biggest fuse in the thing (probably 80 amp). Look through the little window and see that it is blown. Replace.
Check all the rest too.
Old Jun 17, 2016
Tz779's Avatar
ok, checked all fuses under hood. fuse 20, 40amp, Ignition 1 does not show 12v with key on. But multimeter says fuse is not blown/broken. no voltage at alternator. Thanks!
Robin
Old Jun 17, 2016
CraigW's Avatar
No voltage a main lead from battery ?? I only show the 80A as protection.
Old Jun 17, 2016
Robin
You didn't check the 80A fuse?
Old Jun 17, 2016
Tz779's Avatar
yes, it is ok, voltage on both sides of terminals
fuse #4, 10amp alternator, under steering column is ok
Old Jun 17, 2016
Do you have B+ at the terminal marked BAT?
Do you have B+ at the terminal marked ALT?
Old Jun 17, 2016
Tz779's Avatar
ummm, B+? Is that voltage (battery positive?)? i'll check, ive only checked 18 and 19, no current across 19, but multimeter shows continuity(?)
thanks! ; )
Old Jun 17, 2016
thanks! ; )
B+ is always battery positive , or 12v
Test using meter set on volts for live circuits, not ohms.
Old Jun 17, 2016
Tz779's Avatar
Oh, yes, thank you, though. I had battery disconnected to see if I had continuity across 40 and 80 amp fuses. When I hooked up battery, test light lit on 80 amp, but not 40 amp, with key on.
Just got home from work, I'll check in the morning. Thank you for your help! Very appreciated!
Warm regards,
Robin
Old Jun 17, 2016
but not 40 amp
So then the 40A is blown?
Old Jun 17, 2016
Tz779's Avatar
Possibly, but it shows continuity with an ohm meter, and the thinner wire at the top of fuse is still intact, not separated.
So, I unscrewed the 40 amp fuse from fuse block and checked with ohm meter, yes, shows continuity, fuse ok. Installed back in fuse block, battery hooked up, no voltage across the terminals of the 40 amp fuse!?
Robin
Old Jun 17, 2016
Are you using the meter incorrectly?
Meter neg (black) lead attached to neg post of the battery and leave it there.
Probe spots in the fusebox for voltage (B+) using the single positive (red) lead of the meter.
Same if you were using a test light, clip its wire to the neg battery post then probe for power with the sharp end
Old Jun 17, 2016
Tz779's Avatar
Yes, that's how I am testing for voltage. I dropped the multimeter and broke it, so resorted to a test light, as you described. New meter tomorrow!
Tony Alva? That is a valuable skateboard!
Robin
Old Jun 18, 2016
Tz779's Avatar
ezone,
I replaced 40 amp fuse.
I have B+ at terminal marked BAT
I DO NOT have B+ at terminal marked ALT
Does that suggest the problem is between battery and the fuse box?
Best,
Robin
Old Jun 18, 2016
The 80A fuse is blown.
Old Jun 20, 2016
Tz779's Avatar
ezone,
YES IT WAS!
i am sure i checked that fuse, in place in the fuse box and read continuity with my multimeter. i took the fuse out, checked it again, blown.
Thanks so much. I am done with multimeters from Craftsman (Crapsman now), Pep Boys (Innova 3320 that always reads 12,60 volts). I will buy a Fluke when I have some $$.
Now i have to deal with a leak in radiator!
Best,
Robin
Old Jun 20, 2016
But this could have been found with the $3 test light LOL
Old Jun 20, 2016
Tz779's Avatar
yes i was using my test light, which told me i had no power to that BAT terminal. still, the Innova multimeter i bought the other day ALWAYS reads 12.6 volts. Always. i dont trust it...
Old Jun 20, 2016
CraigW's Avatar
Inherent problem with digital meters is the high impedance that puts no load on the circuit.
Good in some cases......bad in others. Your 12V test light provides a good load.
If it reads 12.6 with the leads disconnected.... then it's done.
Old Jun 20, 2016
If he attached one meter lead to each side of the fuse and read battery voltage, then he's not understanding what he saw. (voltage drop test)
If the fuse was good there would be zero volts showing.
An open fuse would show battery voltage.
Old Jun 20, 2016
Tz779's Avatar
i was reading resistance (ohms) across the fuse. (she!)
Old Jun 21, 2016
CraigW's Avatar
^^^ On what scale ?? You would likely only use the lowest (200) setting, and look for 0 Ohms if fuse o.k.
Hope you had a battery terminal disconnected when in resistance function.
alex_nyc
27
Jun 16, 2019 08:27 PM
t.ralsty
Jul 2, 2016 10:24 PM
shriketheavatar
Oct 20, 2015 08:31 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
