Odd intermittent overheating issues
I have an US spec 2002 Honda Civic EX with 106k miles on it and a manual transmission. All gaskets are stock, the timing belt and water pump have been changed within 40k miles.
(Quick summary: Intermittent overheating that happens along with my heater blowing cold air and coolant leaking from somewhere under the air intake assembly, read below for more details)
I was driving on the autobahn in Germany doing about 105 mph - 110 mph for about 30 mins then I pulled over to use the bathroom and when I came back out I noticed my car smoking from the engine compartment. I opened the hood and saw that coolant was leaking from somewhere under the air intake assembly. I got back in the car letting it idle and noticed the car overheating.
I turned the engine off and let it sit for a while to let it cool down and then hit the road again keeping it about 85 mph. I kept the heat on full blast to try take some heat off the engine but randomly it would start blowing cold air and the engine temp would start to climb. It would nearly reach the top of the gauge and then would start to drop and the car would blow hot air. It did this process several times until I finally reached my destination.
My best guess is the thermostat and I have to wait until tomorrow for the autoparts store to open. Until then I would welcome any other ideas, I will do further troubleshooting tonight when I remove the air intake assembly.
Re: Odd intermittent overheating issues
Changing the thermostat is a start (make sure you get OEM or OEM-spec temperatures), but it's very likely that you have a more expensive problem coming.
Do the radiator fans actually work?
First bad move was not refilling the cooling system (radiator).
That promotes continued overheating and subsequent damage.
overheating
blowing cold air
overheating
blowing cold air
I drive the exact same car and have had the exact same problem. I never leaked coolant like you say, but when my car overheated, the coolant would shoot out of the reservoir and all over my engine.
Anyways, after a lot of bad advice from different mechanics, I ended up replacing the coolant reservoir, radiator cap, radiator, thermostat, etc, and still had overheating problems. It only happened when idling, not when driving at 80+ mph.
It turned out to be the head gasket. Fortunately I never let the car over heat too bad and the head never warped. It set me back about $900 at the stealership. I think you have the same problem.
Lukomor
Oct 16, 2015 01:57 PM
Pfatfinger
Oct 7, 2015 12:39 AM
