97 civic cluster gear indacter lights dont work
Old Feb 27, 2016
Civicex97's Avatar
Civicex97 is an unknown quantity at this point
hi im new to the forum i have a 97 civic ex and my dash lights work and everything else works but the gear indacater lights on the gauge cluster i checked for loose connections nothing checked and replaced all bulbs and still nothing please help what can i do to fix this? car drives fine no codes or anything it is the only problem i am having. is there anything else i can try please any sujestion will help please.
Old Feb 28, 2016
Re: 97 civic cluster gear indacter lights dont work
NO codes?
Does the shifter interlock work?
Do the back up lights work?
I guess I'd follow the wiring diagram and use a DVOM to verify a signal from each lever position is reaching the appropriate wire at the gauge cluster.
I'd probably check in the shift position bulb connections to see why it is not lighting up, what is missing, either the hot or the ground for a bulb so I can decide which way to chase.
I'd check for correct voltages on the wires at A1 and A2 in the cluster for operating the the shifter indicator dimmer unit inside the cluster.
HTH
Old Feb 28, 2016
Civicex97's Avatar
yes all my other lights work but the gear indacaters on the cluster the gear indacaters on the shifter console even light up and work but not the cluster ones. and as far as i know the shifter interlock does work. is there a way to jump the wires to make them work temporarly?
Old Feb 28, 2016
If you don't know exactly how it's supposed to work and exactly what you are doing, you're quite likely to cause more damage than you started with.
Old Feb 28, 2016
Civicex97's Avatar
so what if i start with replacing the circuit bord to it then go from there is it a possibility that the board went bad?
Old Feb 28, 2016
Sure it's possible.
I like to prove a problem before throwing money at it.
Old Aug 29, 2016
Civicex97's Avatar
97 civic ex catback exhaust
i was wondering if a 96-00 civic ek hatch catback exhaust will fit a 96-00 civic ex coupe non hatch?
Old Aug 29, 2016
Re: 97 civic ex catback exhaust
You should start a new thread for that topic.
Do you have a fix to post for this thread?
curaze
Sep 22, 2015 08:27 AM
Wiggles
Sep 8, 2015 05:05 PM
01ExSiLvErBuLLeT
Nov 30, 2001 11:05 AM
civicPesek
Nov 7, 2001 11:33 PM
WhosYoDadday85
Nov 3, 2001 11:23 PM
