01 Civic Aftermarket Clifford Alarm Question
Old Dec 8, 2015
Wiggles's Avatar
Wiggles is an unknown quantity at this point
I have an 01 civic that has an old Clifford aftermarket alarm system in it which im looking to remove because i lost the key fob a long time ago and sometimes the alarm goes off when working on it, such as removing the battery. I know i should remove all of the components of the alarm and then fix any wires that were spliced but because of the weather, winter here, i just removed the clifford control unit that is under the dash. The system doesn't seem to have a ignition kill switch or anything because when i remove the unit, the car still starts fine. Is it better to leave the unit plugged into the sensors and not the power or is it ok to leave all the wires unplugged and the unit out from under the dash until i can rip out all the other components.
Thanks for any help!
Old Dec 8, 2015
GolNat's Avatar
Prelude Owner
Re: 01 Civic Aftermarket Clifford Alarm Question
You can leave it unplugged. It will loose programming but you will have to re program anyway since the fob is lost. But if you are not wanting to use it then don't have to worry about that.
Old Dec 8, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
If everything works fine then shouldn't be a problem.
Old Dec 8, 2015
Wiggles's Avatar
Ya im not worried about reprogramming it cause im not planning to use it again. Thanks!
Ya everything works fine, the plugs have connectors on them so they shouldn't sort out if they hit the bare metal or anything right? Would it help to wrap the connectors in electrical tape just to make sure?
Old Dec 9, 2015
GolNat's Avatar
Prelude Owner
It wouldn't hurt. Can't be to cautious.
jferristx
Jul 8, 2015 10:09 PM
Spanky4269
Jul 5, 2015 09:40 PM
hayden55
Jul 2, 2015 06:12 PM
ilgnay
Apr 26, 2010 11:53 PM
vistec
Nov 7, 2001 05:53 PM
