Blown motor, need help!
Old Dec 1, 2015
spatel133's Avatar
spatel133 is an unknown quantity at this point
Hey guys, im new to the forum and could use some advice. I have a 2003 honda civic Lx with a d17a1 with a blown motor. Its got 117k miles on it. seems like the timing belt snapped even though i had it swapped at around 90k at a honda dealership. Honda wont do anything about it. Id like to get it back on the road, but i cant seem to find a low milage d17a1. I see d17a all over craigslist (North Jersey) for like $500. Been reading online to only see if the swap is possible and i read mixed reviews. i attempted contacting people who have tried it but heard no response. Other than the motor, what do i need to buy? read many different things about if i swap the ecu, i need to get the key immobilized at a dealership but not all dealerships can do it since the ecu is from japan. trying to find the cheapest option since im on a budget. I know the car will run but how will it run? how slow is the acceleration?
Old Dec 1, 2015
GolNat's Avatar
Prelude Owner
Re: Blown motor, need help!
So this the motor blown or did the timing belt snap? A snapped timing belt could result in needing a new head.
I would remove the valve cover and inspect the belt. Why do you think the belt snapped?
Old Dec 1, 2015
spatel133's Avatar
well im guessing its a timing belt. what happened was the car was struggling accelerating, than the car's ignition coil blew off, and it wont turn over anymore.
Old Dec 1, 2015
Wankenstein's Avatar
Try cranking it by hand using a socket wrench, extension, 17mm socket on the crankshaft bolt and rotate counter-clockwise. First remove the spark plugs to make it easier to rotate. Also, remove the upper timing cover and valve cover to watch and inspect belt.
Old Dec 1, 2015
It blew a spark plug out of its hole?
May be an easy fix?
Old Dec 1, 2015
mac25's Avatar
Dr Krieger of Modification
...so is the belt still attached or what?
Old Dec 2, 2015
OP you say you're on a budget, yet you want to replace the engine??
instead of declaring "it blew up" and trying to pin blame on the dealers timing belt job (of course they won't do anything when you do as you did) when you really don't know what happened yet....
you should figure out what really happened and see if it is fixable.
if you are really on a budget, this may be far cheaper than trying to stuff a wrong engine in it.
You say it blew a coil out...... experience says that means a spark plug blew out of the hole.....
If this is correct, NOW who installed those spark plugs???
this can be a really easy fix and far cheaper than an engine replacement.
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
qlitten
Jul 21, 2015 03:12 PM
Ariah J. Davis
Jul 20, 2015 07:15 AM
