Misfires and codes with low gas level
Old Nov 12, 2015
tripod007's Avatar
tripod007 is an unknown quantity at this point
Exclamation Misfires and codes with low gas level
I'm having misfire codes with my 03 civic ex. I first got these codes last year and the problem turned out to be a clogged intake manifold. After I had it cleaned out the codes went away for about 7 months. Now I'm getting these codes again, but only when my gas tank is below a 1/4 tank. Once I fill up the tank and drive it for about a mile the codes go away. Anyone have any explanation for this??
Old Nov 13, 2015
Star1967's Avatar
Star1967 will become famous soon enough
Re: Misfires and codes with low gas level
Dirt and debri in the tank. Dirty gas and poor quality is a factor. Have you tried cleaning the tank?
Old Nov 13, 2015
Mad Dog Tannen's Avatar
When did you change your fuel filter last? I am not sure if that is related, but it is often overlooked during tune ups and it can cause issues with idle, startup and throttle response. IF it has not been changed in a long time it probably needs it anyway. considering that you let the air cleaner go that long...
Old Nov 13, 2015
If it's a random misfire code, I might guess the strainer on the inlet to the pump may be clogged, causing it to cavitate and pull air when fuel level is low.
Or is it a single cylinder misfire code?
AngeloS
Jul 16, 2015 11:00 PM
Dobber1
Jul 10, 2015 11:17 PM
hayden55
Jul 2, 2015 06:12 PM
tmc66
Jun 9, 2015 04:07 PM
