Emissions System – Small leak detected question
Old Sep 29, 2015
brash99's Avatar
brash99 is an unknown quantity at this point
Engine light came on for an emissions leak on my 2005 civic. Brought it to the dealer who ran a pressure test and said they could find no problems. Cleared the light and it was fine. The check engine light has come back on with the same error. Other than the leak down test, what should I be looking at?
Thanks
John
Old Sep 29, 2015
mikey1's Avatar
Re: Emissions System – Small leak detected question
what is the code from the CEL?
Old Sep 29, 2015
brash99's Avatar
P1457 Honda - Evaporative Emissions Control System Leakage EVAP Canister System
Thanks
John
Old Sep 29, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
likely cause, (but don't throw parts without diagnosis) are: loose gas cap, plugged vent line, bad purge solenoid.
As previously asked which code did you get?
Old Sep 29, 2015
mikey1's Avatar
i can't remember for sure but i think i had that same code about a year ago,
my problem was caused by the canisters shut off valve leaking,
you can test it by removing the valve, plug one end of it with your finger then blow into the other end, if you hear air coming out then its leaking,
do that test in both directions,
tip - its alot easier to remove that valve if you remove the whole canister from the vehicle
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
juror
May 26, 2015 06:35 PM
green01civic
Apr 29, 2015 01:36 PM
mievil
Apr 28, 2015 11:02 PM
cloudguy
Apr 28, 2015 05:02 AM
