Door stuck locked
Old Sep 14, 2015
nixyfior's Avatar
nixyfior is an unknown quantity at this point
Door stuck locked
Passenger front door is stuck locked. I have everything taken off the inside and can see the lock. I saw a video for a 2000 that had a pin to release the latch but I can't find it in the 2001. Does anyone know if there is a way to release the latch to get the door opened or is drilling a hole in the frame the only way to get the door open?
Old Sep 14, 2015
MassCivic's Avatar
MassCivic is an unknown quantity at this point
Re: Door stuck locked
You should just be able to pull the control rod and pop the door open at that point. Just find the rod that runs to the latch and pull it away from the door jamb toward the front of the car and push the door open. Then you can access the hardware to remove the locking mechanism and replace it if that's the issue.
Old Sep 14, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
if you keep locking and unlocking the door and trying to open it you may be able to get the latch/lock to line up right so you can open the door.
had a similar issue with mine, I took the latch out with the actuator mounted to it and discovered that a little plastic piece broke off the bottom. therefore the lock wasn't lining up properly.
the only pin that i found while taking it apart was inside the latch assembly where it meets the actuator. if you pushed on it it popped the latch loose so you could open the door.
Old Sep 14, 2015
I'd say buy another door latch .....and once you have a good one in your hands you can inspect and hopefully determine where to drill to get the old one to release.
krazykoncepts
Jul 14, 2015 01:55 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
