temp sensor question
Old Sep 9, 2015
Dave Brabant's Avatar
Dave Brabant is an unknown quantity at this point
ok so i was just messing with my instrument clauster when the needle broke to my temp guage. now im going to buy an aftermarket guage but my question is" while looking up how to install it properly, i found out that the temp sensor also sends a reading to the computer to adjust air/fuel mix. This civic has the connector jumped so that the fan always stays on. Does this connector also play a role ? my plugs came out sort of whitish today. Being a new to me car idk if they have ever even been changed
Old Sep 9, 2015
Re: temp sensor question
heres the connector in question(pic 1)
heres the connector ive been told plays with A/F mixture
ID:	88072   Click image for larger version
Old Sep 9, 2015
Pic 1 is the temp switch for the radiator fan. If the fan is kept running all the time, someone may be trying to hide something (like overheating problems)....and it can wear out the fan motor prematurely.
Pic 2 is one of the temp sensors.
The two wire sensor is for the computer.
The single wire sensor (under the distributor?) operates the gauge on the dash.
I see everything in the pic has a coating of oil on it, (but man that valve cover is a nice shade of blue LOL)...... You should check into that.
Valve cover gasket, and an O ring for the base of the distributor are common leaks, and VTEC seals if it has VTEC..
AND inspect the heater hose on the end of the head under the distributor, when that gets oil soaked and swollen it can blow up with disastrous effects.
Old Sep 9, 2015
Yeah the valve cover was leaking i just replaced it while it was off i decided to throw some paint on it because the old gold paint was literally pealing off in the wind. Dont be hating on my blue XD i like it though and thats what counts to me. thanks forthe info on the heater hose and o-ring ill be sure to check that right away in the morning after engine shampoo.
Old Sep 9, 2015
I wasn't hating on the blue, it just stood out as unusual (and fresh) in an engine compartment where it should have been gray or silver.
I like blue, most of my cars have been blue. My last Buick was blue, my current Civic is blue and my Hog is blue too.
Old Sep 9, 2015
Oh ok haha my bad thanks again for the help
Old Sep 10, 2015
Is there a way to install a temperature warning light for the coolant say if it goes over 3/4 a led will flash? Weird question I know but my guage don't work and my after.arket one wo t be here for 2 weeks
Old Sep 10, 2015
Glue a toothpick onto the broken gauge, as a needle?
Old Sep 10, 2015
It broke off at the shaft
Old Sep 10, 2015
Junkyard cluster or gauge?
car-part.com
Old Sep 10, 2015
car-part.com
Thought about it and they all want 100$ for a cluster and they won't sell me just the temp fuel guage section of it as the cluster won't be sellable after. plus I already ordered an aftermarket one.
R3KogHyZe
21
Feb 3, 2016 09:23 PM
Allecr3
May 22, 2015 01:24 PM
Rushfan1
May 6, 2015 01:20 PM
Blaster30
Apr 22, 2015 12:21 PM
viper775
Dec 9, 2001 10:52 PM
