04 Civic "redlines" at 4000rpm
Old Aug 23, 2015
scootz_7's Avatar
scootz_7 is an unknown quantity at this point
Just recently bought a 2004 Honda Civic and am having what i hope is a minor problem hoping someone can help me out.
When driving the car in any gear it has no acceleration or power and will only reach 4000 rpm (slowly) but in neutral it will rev beyond 4000.
Any input would be greatly appreciated
Thanks
Old Aug 23, 2015
Re: 04 Civic "redlines" at 4000rpm
Got Check Engine Light?
Got codes?
Got oil?
Got cam timing??
Got exhaust restriction?
Got intake restriction?
Does it accelerate better if you don't floor the gas pedal?
Old Aug 23, 2015
scootz_7's Avatar
Check engine light is on even tho is was just safety/e-tested yesterday.
Codes
P0300
P0301
P0302
P0304
P0420
It does seem to accelerate a bit better at about 25%-50% throttle
Old Aug 23, 2015
I'd suspect a clogged exhaust
You have a cat code, has the cat broken apart and clogged up the rest of the exhaust? Is the cat itself clogged?
EX? LX? Can you disconnect the exhaust in front of the cat as a test?
Does it misfire now? Misfiring can and will destroy a cat. Fix all other running problems before putting a new cat on.
Old Aug 23, 2015
scootz_7's Avatar
Also just had an oil change yesterday
Old Aug 24, 2015
Just to clarify for OP..
P0300: multiple cylinder misfire
P0301-P0304: Misfire in cylinder 1-4 (respectively)
P0420: Catalyst system under efficiency threshold
That 4000RPM "redline" means your car is in limp mode to save itself from damage.
Old Aug 24, 2015
scootz_7's Avatar
So how would I go about getting it out of limp mode? Does that mean the engine is toast or will it be fine after getting it off of limp mode?
Old Aug 24, 2015
I don't think it is in limp mode, those codes listed do not cause that failsafe mode to come on.
Plus, OP stated this: but in neutral it will rev beyond 4000.
IMO, that's not limp mode at all.
Old Aug 25, 2015
Yeah, I thought about that after I posted and figured you'd correct me. Lol
And clearly, I can't read.
Old Aug 25, 2015
scootz_7's Avatar
Could it be as simple as my catalytic converter being clogged? It is clogged and falling apart from the inside so I irdered a new one yesterday.
Old Aug 25, 2015
Yes, see my reply in post #4.
YOU MUST FIX THE MISFIRE PROBLEM BEFORE INSTALLING THE NEW CAT !!!!
Even a brand new cat can be ruined in a matter of minutes if the engine runs bad enough.
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
