what is this ? 2001 ex
Old Aug 22, 2015
bhollie's Avatar
bhollie is an unknown quantity at this point
when i hit a bump the steering column shakes and rattles... doesnt do it while driving on smooth roads or at high speeds just on the rougher stuff... has new tires, doesnt seem to have any suspension problems.. alignment is ok..
any ideas?
thanks
Old Aug 24, 2015
emich's Avatar
emich is an unknown quantity at this point
Re: what is this ? 2001 ex
any ideas?
thanks
Wheel bearings
Old Aug 24, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Steering column is loose? How big is the bump?
Old Aug 24, 2015
bhollie's Avatar
wheels bearings? how would that affect the steering?
the bumps arent that big but the bigger the bump the more it does it..
Old Aug 24, 2015
emich's Avatar
It is uncommon wheel bearings to cause this. However I am facing now the same problem. It took years for the grinding cyclical noise typical for damaged wheel bearings to appear. Before that I was thinking about anything else but the wheel bearings.
Old Aug 24, 2015
bhollie's Avatar
well it does have 177k on it.. Im sure they are originals.. but i bet they are expensive to replace being that i cant do it myself..
is there anything else it could be? dont want to waste the money unless i have to...
thanks
Old Aug 24, 2015
emich's Avatar
thanks
Wait it's going to get worse and you can identify it easier.
Old Aug 24, 2015
Yep, could be lots of things.
Diagnose what really is wrong.
Or pay for accurate diagnosis
Nobody here can see/hear/feel whatever is going on in your car.
Old Nov 11, 2015
bhollie's Avatar
yeah,,, thanks man.. i realize that.... just wanted some suggestions...
anyway.....wanted to post an update.. been putting up with the noise for a while.. found out my civic is the one with the airbag recall. brought it in, they put the new air bag in.. and poof! no more column rattle... weird right? maybe something was loose with the old airbag assembly or the column itself they wouldve tightened up while installing it... ? anyhow... on to the next noise!!!
Munzy
21
Oct 7, 2015 07:48 AM
thatcham
Sep 30, 2015 08:28 AM
raymondxcho
Sep 29, 2015 09:00 PM
260000milesgoal
Sep 25, 2015 07:41 PM
BBrosario
Sep 17, 2015 07:51 PM
